Surging up the Column!
Casper
Post by Casper »
I am sitting here next to the still and every so often the boiling chips bounce in the boiler and then the take off comes at a faster rate. I am using natural gas for heat and it is maintaining a steady temperature. Any thoughts about why this might be? It has been running quite slowly. I have been pulling off about half a quart every hour or so. It has been coming off at around 92% which I thought was pretty good, but should be able to get a bit higher ABV%. Have a look at my bucket and let me know what you think.
http://s976.photobucket.com/home/buckethead_000/index" onclick="window.open(this.href);return false;" rel="nofollow
All the things I really like are either immoral, illegal or fattening.
My stuff: http://s976.photobucket.com/home/buckethead_000/index
Casper
Re: Surging up the Column!
Post by Casper »
Figured it out. Had a leak around the top of the boiler. My seal got cut when I placed the column on my keg. :oops: This explains the varying rates of take-off.
