Question from a greenhorn
Jethro
Post by Jethro »
OK. So I consider myself an accomplished home brewer and lately I've been lurking on this forum. I really wanna put together a pot still and was looking at putting to use a Sanke keg I have in my brewshed that is just gathering dust. I was looking at putting together a potstill myself since I'm pretty hand with about anything with a bit of help.
I'm thinking about using this Stainless Steel Flange / Ferrule - 2" Diameter from Mile High Distilling.
http://www.milehidistilling.com/Ferrule ... /16622.htm" onclick="window.open(this.href);return false;" rel="nofollow
Anyone know what the ID/OD of the ferrule is? I sent an email to the contact address but didn't get a response. Could this be adapted to copper? Any issues with the gasket they sell for this?
scarecrow
Re: Question from a greenhorn
Post by scarecrow »
Yo Jethro, welcome to the forums.
I don't know if all ferules are the same, but here in OZ I just bought some fittings for a new build.
Here we have a triclover fitting, 2" ferule, 2" to 1" reducer and a 2" elbow.
The 2" reducer is the same size as a 2" pipe. It won't fit over the ferule.
The 2" elbow (that the 2" pipe fits into) will slip over a 2" ferule.
If I was attaching a 2" pipe to a ferule, I would be fitting a 2" joiner first. ie ferule to joiner to pipe.
Be safe.
scarecrow
Kentucky shinner
Post by Kentucky shinner »
Freeze the Ferule and warm the copper pretty good. It should slide right over the top of the ferule and make a really good seal when temps equalize. I hope this helps you out.
Kentucky shinner
I personally bought the 2" adapter with the 2"npt threads on the other end and I use a 2" copper female coupling that screws right on.
