Hello from the North (Canada)
Mutts
Post by Mutts »
I have been interested for some time in home distilling, and am now ready to take the plunge and build a reflux still "for research purposes" :lol:
My intention is to make a 2" dia based on the Stone column design (unless someone can recommend a better version).
I expect I will end up using a water heated for a boiler.
I have been following this forum for some time, and am sure I will benefit from all the accumulated wisdom it contains.
The project is a "no rush" effort, and I have a desire to do it right.
Thanks for the great forum
Mutts
blanikdog
Re: Hello from the North (Canada)
Post by blanikdog »
Welcome Mutts
blanik
Cumudgeon and loving it.
Kentucky shinner
Post by Kentucky shinner »
Good day Mutt, and welcome to the forum.
Kentucky Shinner
Welcome and good luck
mrhooch
Post by mrhooch »
Hello, good to see a fellow canuk here!
It is a lot of fun to build a still.
Hooch.
beelah
Post by beelah »
welcome to another Canadian.
as for design, I would suggest a Bokabob as they are very easy to build and operate and can be used as a refracting still or detuned and used as a pot still if you are looking to make some whiskey.
The other option is the design that Rad has developed which was my second build and which I find a very good design, with a minimum of soldering necessary.
I will find the string here an post it for you to take a look at.
I am on the west coast of Canada, where are you?
beelah
Post by beelah »
Here is the link http://homedistiller.org/forum/viewtopi ... =17&t=8439" onclick="window.open(this.href);return false;" rel="nofollow
Mutts
Post by Mutts »
Beelah....
Used to live on your coast, but got moved to Ontario.
I"ll be back.
Thx for the link.
Mutts
mrhooch
Post by mrhooch »
No kidding, I'm in the north GTA...
You can't really go wrong with a water heater for a boiler, that's what I use, check craigslist and kiiji for them, slightly used, but you need to gut them anyways.
As for the type of still, they all do work, it is more a how complicated do you want it to look. :shock:
Hooch.
beelah
Post by beelah »
when you decide on what you are going to build post some pictures as you will see we all love copper porn
kiwistiller
Post by kiwistiller »
The boka or VM is indeed a better choice. Can't comment on rad's in detail but I understand it is similar in operation to the boka. The VM is a more complicated design to build that probably has a nose ahead in performance, and the boka is easier to build.
Three sheets to the wind!
My stuff
