Reflux coil for plate collumn
pumpman
Post by pumpman »
Hey Olddog here's one of the coils for my twin project.
Re: Reflux coil for plate collumn
D'jew freeze that pumpman?
Looks tidy.,Keep it comming.
olddog
Post by olddog »
Looking good Pumpman, What size tubing did you use for that mini-coil? if its 3/8"inside a 3"cap, that gives me more hope for winding the coil for my new condenser.
OD
pumpman
Post by pumpman »
1/4" soap and water filled and frozen then wrapped around a 1" pipe and placed inside a 2" cap.
olddog
Post by olddog »
We want to see more copper, where's the rest of the column. :mrgreen: :mrgreen: :mrgreen: :mrgreen:
OD
pumpman
Post by pumpman »
Workin on it Mike. I messed up the rest of my tubing because it melts to fast. It was probably 100 in my garage today.
olddog
Post by olddog »
Can't wait for that warm weather to return, it's bloody cold by Oz standards here today especially in the mornings. :esad: But I suppose its warm compared to UK temperatures.
OD
Post by The Baker »
pumpman wrote:1/4" soap and water filled and frozen then wrapped around a 1" pipe and placed inside a 2" cap.
I suppose you used dish-washing liquid for the soap?
If it was a good quality liquid (or if it wasn't, but the cheap stuff is a lot weaker I think);
could you give us an idea of how much to put in the water?
Thanks a lot.
olddog
Post by olddog »
I am wondering if the detergent has a lubrication factor, to allow the ice to move when bending.
OD
pumpman
Post by pumpman »
Yeah Baker I used Dawn dish soap but I'm affraid I'm a little unsientific. I just put some in a cup and added some water and froze it. I didn't even use anything to hold the end of the tube. Just worked it around the pipe with my hands.
Post by The Baker »
pumpman wrote:Yeah Baker I used Dawn dish soap but I'm affraid I'm a little unsientific. I just put some in a cup and added some water and froze it. I didn't even use anything to hold the end of the tube. Just worked it around the pipe with my hands.
About the same amount as you would use to wash dishes or a bit more?
(I'm not very scientific either!)
pumpman
Post by pumpman »
A bit more just play around and find what works for you. 1/4" tube is pretty cheap.
HookLine
Post by HookLine »
Looks like soap and water works at home freezer temps. Might be just the trick we need for easy coil making.
Be safe.
Be discreet.
And have fun.
pumpman
Post by pumpman »
Well Hook it is easier to fill the 1/4"tube with liquid then salt, like I said it melts pretty fast so you have to work fast.
