Coal Filtering
Coal Filtering
Aquarium charcoal reads on the packet...............activated charcoal removes odors and particles.
Can I use it for filtering spirits?
Re: Coal Filtering
if you are going to filter git the right stuff, I hear that stuff is nasty
Re: Coal Filtering
Dnderhead wrote:if you are going to filter git the right stuff, I hear that stuff is nasty
yes........ I know a guy who tried it.
buy the food grade stone carbon. its the best
-Control Freak-
AKA MulekickerHDbrownNose
Re: Coal Filtering
Fair enough. Thanks for saving me a mistake. But the stuff is so small, how do I effectively remove the dust without losing half my coal?
Re: Coal Filtering
boil it, strain it, boil it. do that many times till the water comes out clean.
-Control Freak-
Re: Coal Filtering
I thank if you stir it up the fines will be suspended and the bigger stuff will settle,then just pore them off
Re: Coal Filtering
Like these guys said. Do NOT use anything but carbon designed for filtering human drinking water. Mile High sells great stone carbon for cheap! One bag costs like $4.00 and it will filter like 10 gallons of 80proof (if your water is pure). Also I don't pre wash my carbon as I believe you loose some efficiency when you do I just take a gallon glass jar and cover the opening with an unbleached coffee filter as my collection jar.
Re: Coal Filtering
I had a horrible vision of someone filtering through soft coal dust
Re: Coal Filtering
To eliminate much of the charcoal from getting into the product, I use a filter that has a few inches of sand on the bottom, and then a few inches of charcoal above that. The sand helps keep that black dust at bay-- you get some but not as much.
Re: Coal Filtering
""I had a horrible vision of someone filtering through soft coal dust""
much of it is coal ,it has been "baked" that burns out softer parts then steamed leaving it porous .therefor more surface.
Re: Coal Filtering
you can recycle yer carbon too. throw it in a plain pan (no teflon, or coatings) and cook it till it glows red hot. then wash it real good. do this outside....it stinks. and be careful when you start, all those fumes yer cookin off the carbon are flameable. they will flash.... i found that out first hand, lost some facial hair that day.
-Control Freak-
Re: Coal Filtering
Also a good source for activated carbon of extremely high quality is respirator mask filters. I know where I work we toss out brand new unopened ones all the time due to expired shelf life. Pretty sure they will work fine for filtering your hooch after they become outdated though.
