Purple wax residue, best PH ? baking soda for whisky?
adimeshort
Post by adimeshort »
apologies if this subject is an old one, i've done my best in searching for the answers that relate to my problem
Question1: why am I ending up with a seemingly waxy, “stale-purple and copper dust” colored residue inside of my column, lyne arm and beginning of condenser? Is this bad? The low wines don’t appear blue- before filtering with coffee filters it had a copper color, now slightly cloudy but clear.
The washes have been acidic before distillations
Question 2: what is ideal distilling ph for single malt whisky?
Question 3: I’m making single malt whisky, should I use baking soda after first distillation to help delineate heads, hearts and tails? Or will this create too much of a vodka whisky with heads and tails that I wouldn’t want to add due to possibly ?compressing into 'undesirables'?
My wash ends up acidic PH4-5+ using alcotech super start distillers yeast (i don't believe it has added nutrients- its a 1lb bag good for 1000-2000 gals mash).
there is definitely a learning curve to not combining too much heads or tails- i will be doing small, experiment blending from now on.
This is my third time with the same arrangement:
*12 gals wash @ pot abv 7.8%
-used local 2 row malting barley seed, untreated, floor malted very well
~30lbs @ 60-100% modification
-****(could this be the variable?) added few lbs Peated barley (smoked at low temp, sphagnum moss, No Nutes)
*AlcoTech Super start distillers yeast- . ferment smells acidic, banana, honey sweet (pleasant smelling), Low wines and spirits smell fine also of similar character- I plan on trying an ale yeast next batch
*Pot still ‘the whisky rebel’: 15 gal mega pot with ~2ft copper pipe column, NO Packing 3” – 2” – 1.5” – 1.25” – 1” - .75” (all those reducers add up lol)
*1500 watt cast iron electric hot plate
I have read on this sight, while reading about adding baking soda, that having a wash distillation that is too alkaline can ‘free’ ammonia molecules and create “blue crystals”, “blue low wines” etc.
All three batches have had the same residue but different PH's… Am I too acidic on distillations?
-First two batches I mashed with water at PH 8 (no correcting), ending fermentation PH at probably 6 or under, not sure. (fg .98-)
-Last batch I mashed at PH 5, let to ferment at that and locked out, added some crushed ‘Tums’ but still ended up locked out at PH low 4’s with FG 1+) before throwing into still
Two pipes after distillation, One rinsed and one not rinsed
inside of column.  Notice the stains that do not rinse out and are quite difficult to remove.  I use pumice and a scrub pad where i can
residue rinsed from a pipe
low wines, abv 35% before adding feints from last batch
lastly, for fun, the 'whisky rebel'
adimeshort
Re: Purple wax residue, best PH ? baking soda for whisky?
forgot to mention that im using local spring water (drinking, filling fountain) that i have not tested (not sure about metals, nitrates etc....)
and,
Much thanks
Cheers
adimeshort
Dnderhead
Post by Dnderhead »
blue spent wash is usually high acid,, alkaline,makes blue spirets, a pH of 4-5 is good, so wondering if it isn't something in the water, maybe nitrates or sulfates that is turning to acid when heated. (try a diferant water) no carbonates in wisky.
