Making a Keg Boiler
bencornish
Making a Keg Boiler
Post by bencornish »
Hi All,
I had a couple of newbie questions around converting a Keg.
I want to keep the top as is and Clamp my column onto the Key top uncut.
Whats the easiest way to get a Valve onto the bottom of the Keg ?
Ive cut the hole, however the keg wall thickness is not enough to simply screw it on ?
Can it be loosely screwed on and then soldered ?
Or is welding possible ? Can Brass be welded to Stainless ? or do i need to go buy a stainless threaded Tap ?
I also have a similar issue with my heating element.. its a thread version too :(.
Can I just take it down to my local engineering shop ? or will a Branded Keg cause me issues you think ?
Kentucky shinner
Re: Making a Keg Boiler
Post by Kentucky shinner »
I had a stainless nipple welded on mine. check this post
http://homedistiller.org/forum/viewtopi ... 31&start=0
