Oranges overdone - I've done it again.
Being too lazy to look it up I've ended up with another concentrated spirit -soaked the peel of three navel oranges in a pint of 90%. Distilled off 3/4 of it before the flavour started tasting iffy.
Had to dilute the distillate 5:1 with neutral spirit before I got something that could be taken to 50% with syrup without turning into a white haze. Tastes good over ice though.
Ah well, having a few bottles of concentrate makes knocking new batches much simpler - just keep a stock of neutral around and I can mix as and when.
When my agaves reach full size ( currently about 5cm across ) I'll be self sufficient in Margaritas
Watershed.
Watershed.
Fruit skins tend to haze up on me too when macerated in higher proof. I think part of that is the fact they may have wax on them if commercially grown.
Also, the syrup will add a haze if the syrup warmer than the distilate is when added.
My limoncello turned out bright lemon yellow, but when left for a week or two in the cabinets it seperates and the heavily sugared portion settles out to the bottom and starts forming a clear band at the bottom of the gallon jug. Looks fine after I shake it back up again.
That haze is most likely essential oils perspirating out of the liquor. Those oils tend to be alcohol soluble, so when you extract them in a high-proof liquor, you get a great deal of the oil. Diluting the spirit makes the alcohol less capable of holding the oils dissolved in it, so they perspirate out as a white haze. Same basic principle that applies to ouzo and absinthe. Though hazy, the alcohol should be plenty drinkable.
Re: Oranges overdone - I've done it again.
Watershed.
the only time that i have ever orange flavored a spirt. i used 90% and stuck a piece of dental floss though the orange and suspendend it abouve the spirit so that the evaporating fumes would adhere to the skin and pull the oil out that way. but i havent waterer it down yet i think it will dillute the orange flavor.
when is never enough?
Removing the wax takes all of a couple of seconds with a bit of water and a pan scrubber.
To make an alcoholic solution from the peel you have to steep in in alcohol anyhow and a certain amount of bitterness is desirable in the final product.
Depending on my mood I've either been taking off the peel with a fine knife leaving most of the pith behind or dicing the whole fruit, removing the few pips and chucking the rest into high proof neutral.
Incidentaly, Vim over here is a rather old fashioned scouring powder - I wouldn't let it near anything, particularly food.
You can get special products for cleaning veg? Carrots round my place are lucky if they get a quick wipe with a damp cloth.
If you are chasing bitterness then it may be worth tracking down some dried Curacao peel and using that in place of the Navels. That's what the Belgian beer brewers do. The orange oil aroma, however, will be less.="Watershed". To make an alcoholic solution from the peel you have to steep in in alcohol anyhow and a certain amount of bitterness is desirable in the final product.
