A quick question on "huffing"
therealraycharles
Post by therealraycharles »
When I built my new liebig I read pretty much every forum post on the topic, and it works great. I only get (what I thought was) huffing when I turn the boiler all the way up and turn the cooling way down; so yay for me. I had though that huffing was the little "puffs" of visible vapor that periodically come out the end, lost ethanol.
However I noticed on my last run that there is also a small, constant air pressure coming out of the condenser. It's a very slight amount, I only noticed it when I had my wet finger near the output. The air is cold in temperature, so I don't think that it's lost ethanol, but I just wanted to confirm with the more experienced folk that this is normal behaviour.
20L Stock pot
1 Gallon glass jar thumper
24" Liebig
Dnderhead
Re: A quick question on "huffing"
Post by Dnderhead »
Most liebigs huff at least a lil bit.
This can cause a some splattering while collecting and an aggravating hydrolic affect while using a parrot.
Vapor loss is another issue.
therealraycharles
LWTCS wrote:Most liebigs huff at least a lil bit.
Thanks, I've actually read that all the way through a few times already. My condenser takes those things into account (the cooling supply, the scrubber, etc). I know that the "puffs" can be normal, and I have done several runs without the "puffs".
My question is related to the constant flow of air that comes out, is that "vapor loss"?
20L Stock pot
24" Liebig
Dnderhead
Post by Dnderhead »
I thank your fealing the cold not air movment. try a puff of smoke.
