The second Herter's MUSTIMETER is the same as the first AND also has a thermometer in it with a range from 20 degrees to 120 degrees. I'm assuming that is in degrees Fahrenheit and not Celsius. Then to the right of the degree markings and the actual thermometer itself is another scale in read that runs from the top marking starting at 4.0 - 3.1 - 2.2 - 1.5 - 0.7 - 0 - 0.7 - 1.1 - 1.4 - 1.7 - 2.0 with the following "Above 0 add, below 0 subtract - As many tenths as indicated by Figures"
I understand the Specific Gravity side of things, but I'm not sure about the "Alcoholic Strength after fermentation" scale. What does the scale of 4 down to 18 stand for? On the "Above 0 add, below 0 subtract" scale. I think that has something to do with some sort correction due to temperature?
Thanks for any help.
