3D Drafting program Rhinoceros 3d
decoy
Post by decoy »
The program i used to do the 3d still drawing is Rhinoceros 3d
you can download a copy from here
http://www.rhino3d.com/" onclick="window.open(this.href);return false;" rel="nofollow
i can also post a crack for it if you cant find it on the net..
the program as i rcall is fully functional with limitations on exporting saving renderd images.
decoy
Post by decoy »
the main fetures you want are:
standard box cylynder toroid etc..
then the following items..
Boolean add and diferance, to punch or drill parts.
spiral curve, to crate spirals eg condenser coils.
and under edit there is a join comand to join the curves, you need to but up the curve ends very closly to join them.
pipe, which will crate the larger diameter pipe around the spiral you have crated.
use the online tutorial
and use the in program help to find additional details on each of the commands..
hope this helps geting you started
decoy
Post by decoy »
here are links to a couple of drawings i did...
http://www.push.com.au/images/angle%20t ... e%2007.zip
http://www.push.com.au/images/150mm%20p ... r%2002.zip
this will give you somthing to look at and play with while learning to use rhino..
cheers
FAROM
Post by FAROM »
You have been kind, thanks. :wink:
stoker
Post by stoker »
I could make it in Auto Cad, but saving it as picture isn't possible, is it?
I'll maybe download it and ask for a crack
thank you
-I have too much blood in my alcohol system-
knuklehead
Post by knuklehead »
If you use Auto Cad you can do a cheat way of saving it as a picture buy using your "print screen" feature on your keyboard (alt/print screen) and pasting it somewhere you can save it as a .jpg
Dane Cook
TN.Frank
Post by TN.Frank »
Will it run on a Mac? I've been looking for somekind of freeware program to use since I got my CAD/Detailed Drafting Certificate. We used AutoDesk Inventor, it's pretty cool but I hear that Solid Works is suppose to be even better.
In God We Trust, All Others Pay Cash.
decoy
Post by decoy »
i have solid works 2006 but this is very similar and a bit easyer to use..
also it integrates with 3d animation prg like 3d studio max, Lightwave etc...
ill post a link to the crack l8er...
rectifier
Post by rectifier »
Hey Decoy, do you know any linux-compatible 3d modelling suites? I love Solidworks but can't use it at home on my linux system.
decoy
Post by decoy »
no i dont sory ill ask a freind l8er who is a mac freak... :roll:
stoker
Post by stoker »
knuklehead wrote:If you use Auto Cad you can do a cheat way of saving it as a picture buy using your "print screen" feature on your keyboard (alt/print screen) and pasting it somewhere you can save it as a .jpg
I don't like the quality of those pictures. but I was aware it is a solution
ty
