Hotplate thermostat question
I got a question about bypassing my thermostat on my element.
Its 1000W hotplate with an on off switch and a dial for temp settings. When I use it on high it cuts off and causes the boils to surge and my spirits dont drip equally.
If i bypass the thermal switch will this cause the element to always be on full blast correct? Basically makeing the dial for temp setting inoperative? Is this what I should be doing? Or should I still be able to have some temp controll...
I use an 18 quart stockpot...
Is it going to burn out the element if theres no thermal switch shutting it off ever 30 seconds? Is full blast too much heat for my 18quart?
Ive done allot of searching and there isnt much detailed info about this, im scared of frying my element.
Your experienced explinations would be appretiated.
tks,
C. Moron
tks,
C. Moron
CM,
If you give us some details about our brand and model of hotplate we might be able to help out more.
A sloppy rule of thumb is that if the thermostat is cycling a lot on high then the element will not live long if the thermostat is bi-passed.
Making sure you have the best thermal transfer between your element and the boiler and a good thermal diffuser to help dissipate the heat, can reduce or eliminate the cycling on and off you are experiencing.
I'm sure there is more that I have missed.
As you can see there is no one answer without more details.
Its just a cheap one from Walmart (superior) It simply consists of power cord, on/off switch and thermal switch with a dial.
The power cord goes in, one wire connects to the on/off switch, the other wire goes to the element. From the other side of the element there is 2 wires, one goes to the on/off switch, the other goes to the thermal switch, then wire from the thermal switch to the on/off switch.
Thats everything inside.
Theres excelent heat transfer, its a flat bottom stockpot...
I bypassed the thermal switch last night, should I put it back inline to be safe? Like is it gonna burn out the element in one run?
What kind of still are you using it for? You may not have any need for power control.
Don't run the hot plate without somthing on it to soak up all the heat is generates (like a pot of wash).
You could test out the element by using it to boil off a few gallons of water. If it can handle that without burning out, it will likely handle your wash.
Im using it for a potstill... It works with the cycleing on off, but Im looking for more efficiancy. I feel when it cycles off its lost boil time. The spirits come out in spurts... wouldnt a constant drip be more efficiant?
Anyway, if you guys dont think its a big deal, I will wire the thermal switch back in and just live with the surging collection...
Captian...You should be ok if you:
1 don't have particles in your wash (filtered, or just sugar wash)
2 have a condenser that can keep up with 1000wats of steam
3 be sure there wont be a boil over , or mash swelling that could push solids up into your lyne arm and condenser, causing a pressure buildup and posible explosion.( see condition 1)
For your stripping run, there shouldnt be a problem( no cuts anyway).
Foreshots are foreshots in the spirit run, and will always be first, but if you collect in multiple containers, there shouldn't be trouble...but experience tells me that it is always good to have options available. You may want a slower heat source for the spirit runs...can you use a kitchen stove without attracting suspicion? Experience and experimentation with your rig will give you the lowdown better than our conjecture.
Spirits often boil faster than expected (certianly faster than water).
Hello Cap'n, I have a teeny lil 4-liter (1-gallon) converted pressure cooker still that I started out with and still use to do small quantity runs on occasion! I also use a "Walmart" Special (1100watts maximun) hot plate with the same set up as yours. Sure it surges as it cycles, but in my case it's a very short cycle. I also use it with my larger 16-liter
(4-gallon) ss "Stock pot" still, it just takes forever to get it uo tp running temp, but works fine otherwise. One alternative for me is to bring it up to temp on the kitchen stove and then CAREFULLY move the pot to my "hobby-house" (shed) where I finish the run on the hot plate.
Hey, it works for me! I have read that a lot of people use internal heating elements that range anywhere from 1500-watts to 3500-watts, in 5-gallon stills. Most are probably reflux types, but thats still a lot of energy to manage in a small vessel. Most (indeed probably all) electric range (kitchen stoves) surface burners used in the USA, can operate at a maximun of 1500 watts, anyway. I would think that your little "Walmart" special will work fine just as it came from the store.
Lotsa luck,
Spiritmaker
Lotsa luck,
Spiritmaker
- Tater
Cast Iron heatsink
Hey "tater", that's a good suggestion, thanks. I'll try that with my setup as one thing is certain, the heatsink will keep my lil pot "cooking" till th hot plate cycles again so it'll be as there was no interruption at all.
Thanks again (I didn't think this through before and I know darn well it works too!) Imadummy2
Spiritmaker
Spiritmaker
- Hilltop
Re: Hotplate thermostat question
Most step up to a 1500 watt plate. I run a 1300 electric skillet that I took a metabo slicing blade and removed the sides of. I suggest nothing under 1200 watts, 800 watts won't cut it, I tried one of this way back on 4 gallon washes and I am thinking of going the water heater element route when I build the 32 gallon stockpot.
You need to be able to make strip runs faster and if a thumper is used the more power the better. " You can always turn it down right!"
You could try two heat sources in a bind, I once cooked off two batches on a 750 watt hotplate, with my soldering torch as backup. Not recommended, spend some money and get a better hotplate with more power,
I once saw these strip heaters on pipe in the winter in a refinery, they just wrapped it around the pipe and plugged it in. Those would work but I have no idea where you get them.
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
