Standard Reflux Stills
Posted: Thu Mar 02, 2006 5:35 pm
by Peachey
I'm using a Still Spirits 25L Reflux Still and get 70 - 75% ABV from a 25L Sugar wash using Still Spirits Turbo Yeast.
Is there anyone out there getting better results from the same or similar still?
Has anyone modified their still to get an improved yield?
Posted: Thu Mar 02, 2006 9:34 pm
by Longhairedcountryboy
Hey peachey,
I have no personal experience with this, but I did read a few posts here about it. It's a cooling management still with the coolant pipes running through the column, right? From what I have read, the purity of the product is determined by the temp and rate of the coolent flow. If you run a search (link at top of the page) for still spirits still, you sould find it. The post was quite old and in the research forum, I think.
Posted: Fri Mar 03, 2006 12:59 am
by stoker
someone wants to sell it
http://homedistiller.org/forum/viewtopi ... highlight=
they use it:
http://www.users.bigpond.net.au/home_drinkers/" onclick="window.open(this.href);return false;" rel="nofollow
Posted: Fri Mar 03, 2006 1:41 am
by Peachey
The pictures on the site looks like a Super Reflux... but what they have done is extended the column. I might research the benefits of that.
Thanks guys.
Posted: Sun Mar 05, 2006 5:51 pm
by Peachey
Thanks for the lead Stoker.
What I'm going to do first is pack the column of my current still with a scrubber. I've only managed to find 2 types here in NZ without added cleaning contents, A 3M Gold (Copper and Zinc) and a Stainless Steel tyoe one.
I've also investigated adding an extension to the column made from a 40mm copper pipe, and connectors which I will fill with ceramic beads. I'll try adding this after my next run with just the scrubber added.
I'll let you all know how I get on.
We use one
Posted: Sun Mar 05, 2006 8:36 pm
by pipe_cleanner
I'm using a Still Spirits reflux still modified as "Peachey" said and I stuffed a copper pot scrubber inside my reflux getting 93%, Last time one test came back at 94% I was happy, You will use less water to, running at 74oC+
Any questions email scrb@bigpond.net.au
Posted: Sun Mar 05, 2006 9:16 pm
by Peachey
I can't take credit for the idea Pipe Cleaner. It does have a remarkable resemblance to one I've seen on your site. :D
Posted: Sun Mar 05, 2006 9:43 pm
by pipe_cleanner
Why you want to my credit Peachey , yes Its the one off my site, Just thought you'd want some info on it.
The % I quote on the web page it a hot percentage (around 40oC) scaled down to a 20oC temp.
So a 94% a 40oC = 92% at 20oC
+ i'm not taking credit, It was soo much cheaper than the other one
Posted: Sun Mar 05, 2006 10:56 pm
by Peachey
I agree on the price thing. The difference between a Reflux and Super Reflux is quite remarkable, considering the slight difference.
Big thanks for the info.
