Butter Fingers....Oops!
After doing a 15 hour stripping run and having been up all night, i was testing the over-all amount. Filled cylinder, turned to put hydrometer in and... yep, you guessed it, DROPPED the tube. Luckily it landed on a 5 Gallon carboy, shattering only the cylinder and spraying glass and liquid all over the floor. Now I just have to find another one.(50 ml. Pyrex, single Metric). Remember,... Safety First!
Re: Butter Fingers....Oops!
rainman08 wrote:After doing a 15 hour stripping run
I do all my own stunts
- LWTCS
So,,,,,either 15 bazillion gallon boiler charge.........Or an 18 watt heat source..rainman08 wrote:15 hour stripping run
Your a better man than me.
Fifteen hours is a long time for a hobby stilling run, rain. In fact, it's a #$%^&* long time!!!!
Cumudgeon and loving it.
Yup, about four hours from lighting the burner to stripping down for cleaning is the max for me.
OD
OD
- LWTCS
Where it not for my samaratin like sensibilities,,,,I could have found your foul use of the language offensive.....blanikdog wrote:it's a #$%^&* long time!!!!
For crisse sake every one knows it is spelled $$#^//&*
Bloody foreigners.
Sorry for the profanity, Larry. This forum needs a spell check.
hey, good news... I got run down to only 13 hours.(15 Gal., collecting 3 gal. 50% low wines) also found old baby bottle with milimeters on it.
agree, 15+ hours is a little long. Wouldn't be surprised if I dropped something by the end of that either...
My 10 gallon strips take about 3 hours, 1 to come to temp, 2 to run. I did take about 6 hours to run a spirit run of 80%, which I was not expecting, but a strip should go pretty fast depending on the set-up.
and I thought I was patient with an air coil...
ScottishBoy
HD Survival in a Nutshell...
15hr stripping run?
How long does it take to do a spirit run?
