Red star yeast
Red star yeast
I'm new here and had a question about yeasts. I see a lot of mention of specific "numbered" strands of yeast and could not find a number on mine. I bought red star quick rise yeast and was wondering if it is the same type of yeast I see many peopole using. Also if anyone knows what ABV it'll get, I assume it is baker's yeast. It comes in 3x7g packets.
I use the RedStar active dry bakers yeast that comes in the packets that are 3x7gr .
I use all 3 for a 5 gallon batch, and get between 12-14%abv
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
Thanks that is exactly what I needed to know.pothead wrote:I use the RedStar active dry bakers yeast that comes in the packets that are 3x7gr .
I'm starting 2x5gallon batches tomorrow with 3x7gram packs of that yeast in each can. One I am using the 5kg of cane sugar, the other 2.5kg of cane sugar and 2.5kg of brown sugar.
They are really just a test trial to try out my setup.
you'll need some nutrient to feed the yeast in order to get it up around 12-14% .
try 1 6oz can of tomato paste and a tbspn of lemon juice for each 5 gallon batch.(it won't affect the taste).
[quote="Griff7887]I'm starting 2x5gallon batches tomorrow with 3x7gram packs of that yeast in each can. One I am using the 5kg of cane sugar, the other 2.5kg of cane sugar and 2.5kg of brown sugar.[/quote]
Thats about 2lb 3oz per gallon it should give you a SG of roughly 1101 with a Potential Alcohol of 13.8% according to one chart that i have.
so you should be fine with this yeast.
Be Patient God aint finished with me yet
Quick Rise Yeast are different strains than Active Dry Yeast. Quick Rise Yeast are grown with a higher level of nutrients and are dried to lower moisture content. The particle size of Quick Rise Yeast are finely granulated to allow complete hydration of the yeast cells during the mixing process. The Traditional Yeast has larger particle size should be dissolved in water to achieve complete hydration prior to adding to the mixer. Where Quick Rise should be added to the dry ingredients, In addition, Quick Rise Yeast contain ascorbic acid resulting in increased loaf volumes.
I beleave that either one should be rehydrated for what we are using if for.
