Calories in Ethanol?
TheGinz
Post by TheGinz »
How many calories are in ethanol? And is ethanol a carbohydrate?
Still Spirits Super Reflux Still
25 litres
110 volts 60 cycles 1,380 watts
Construction Body: Stainless Steel
head: Enamel copper
Used in pot still configurgation
Tater
Post by Tater »
http://www.nutritiondata.com/foods-0140 ... 00000.html" onclick="window.open(this.href);return false;" rel="nofollow
Big J
Post by Big J »
Found this on the web:
The calories in alcoholic beverages come from alcohol, which contributes 7 calories per gram as opposed to 4 calories per gram for protein and carbohydrate and 9 calories per gram for fat. So if you take 7 calories per gram times approximately 14 grams of alcohol per jigger (1 1/2 ounces), this equals 98 calories. If the alcoholic beverage such as a liqueur also contains carbohydrate, then the calories for this beverage will be even higher and you can multiply the grams of carbohydrate times 4 to get the carbohydrate calories.
