proofing parrot dimensions
white_likker1
Post by white_likker1 »
Can anyone give me the length of the main tube? Can't find it anywhere.
Chew on this: In 1920 During Prohibition, President Harding kept the White House well stocked with bootleg liquor.
Dnderhead
Re: proofing parrot dimensions
Post by Dnderhead »
mine is 3/4 X11in but this will very with hydrometer.
white_likker1
Thanks dunder
BigPa
Post by BigPa »
WL- measure your alcometer. Make the tube the same length as your meter. Put just a little rolled up piece of copper mesh in the bottom. The mesh will help cushion the meter and it will make the alcometer just barely stick above top of the parrot tube.
Braz
Post by Braz »
It has to be tall enough for your hydrometer to float in it and has to be big enough diameter that your hydrometer doesn't bind by hydraulic tension to the sides of the tube. Mine is 1"x12".
Braz
Washashore
Post by Washashore »
And as Prairiepiss always suggests, don't forget to pack a little copper scrubber in the bottom so it doesn't commit suicide on you!
vetting
Post by vetting »
All of the ones that I've made and sold (over 20 of them) have been 11.5" x 1"
1" provides a more accurate measurement if you are doing a fast takeoff - the rising liquid doesnt make the meter bounce up and down then.
Prairiepiss
Post by Prairiepiss »
Washashore wrote:And as Prairiepiss always suggests, don't forget to pack a little copper scrubber in the bottom so it doesn't commit suicide on you!
I don't know why them damn things are so depressed. They are always killing themselves. And they got the life. Just bob up and down in alcohol. :thumbup:
Washashore
The first hydrometer I bought came in a plastic tube. The bottom of the tube was capped rather than moulded. Wouldn't ya know it, the suicidal bugger blasted the cap right off and smashed on the floor. After ordering a new one, I noticed they began packaging them in a moulded tube. Kind of like making a mental patient wear a helmet I guess :ebiggrin:
white_likker1
Thanks all. I am in the process of making my first. will post pics when its done.
vetting
Post by vetting »
Here is the style that I make - let me know if you have any questions.
white_likker1
Well here it is. I don't think it's too bad considering i have never soldered pipe in my life. Any way it's all polished up. Someone said I could coat it with clearcoat to keep the shine is that right?
white_likker1
vetting wrote:Here is the style that I make - let me know if you have any questions.
Man that is nice. Gotta try that style some time.
BigPa
Post by BigPa »
Both of those are very nice.....
Uncle Bryan
Post by Uncle Bryan »
white_likker1 wrote:Well here it is. I don't think it's too bad considering i have never soldered pipe in my life. Any way it's all polished up. Someone said I could coat it with clearcoat to keep the shine is that right?
Just a quick question, white_likker1
Does the main body extend a tad bit above the reducer fitting?
Uncle Bryan
vetting
Post by vetting »
On mine I usually put the main pipe about a 1/4" above the fitting - makes it easier to read the proofer. They also are a bit nicer if you use a 1 1/2 instead of a 1 1/4 adapter and put the output pipe as low as you possible can - but you usually have to use a drill press to pull that one off.
white_likker1
it actually does not. I started building without any plans to follow. I plan on building another one very soon. This time I know what I am doing and am going to make a tutorial on how to build one along with schematics.
astronomical
Post by astronomical »
you could always add a 3/4" coupling to raise it a bit. If you're scrappin that beauty send it to me.
thump keg
Post by thump keg »
Mine is 10" tall I use 1" ID pipe and modified some reducers to make the base and the overflow urinal and 1/2" OD tubing on the inlet and 3/8" OD tubing on the outlet.
Here's a pic of it before I completely finished it. this one is stainless but you can use copper stainless is more readily available for me.
The secret to creativity is knowing how to hide your sources.
Bayou-Ruler
Post by Bayou-Ruler »
I have one and they are indeed nice!
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
