Plastic Test Tube
Plastic Test Tube
Hello guys. I need some advice. I just purchased and alcoholometer along with a plastic test tube for the alcoholometer to measure in. I wasn't thinking when I bought it that plastic was a no no. Do you think that this would be ok for the short term the distillate is going to be in the test tube. Appreciate all the helpful advice. Just want to be as safe as I can be.
Thanks again.
Thanks again.
Re: Plastic Test Tube
doubt it will last long b4 the distillate makes it crack ...i wouldnt use it myself...then again my glass one cracked this week also...ws the suddon thunp against the SS backspash of counter tho...2 on order now with new meters...just incase
3' Essential Extractor PSII High Capacity (Brewhaus) on gas,recirculating 60 gal olive barrel for cooling
Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for ~ Socrates
Word to Big Bird!fullhouse wrote:doubt it will last long b4 the distillate makes it crack ...i wouldnt use it myself...then again my glass one cracked this week also...ws the suddon thunp against the SS backspash of counter tho...2 on order now with new meters...just incase
I cracked a racking cane in less than a minute with feints!
Just wouldn't risk it. Glass is cheap and proven!
Everything I do or say may or may not have really happened... or it may or may not be all bull shit!
Turning money into steam and likker 10 gallons at a time!
I just want Uncle Sam to be more like Uncle Jessy!
I still remember what happened when I poured some hi test into my plastic test tube...
It turned white... instantly... and the clear distillate got cloudy...
so, no... It makes a nice rain gauge tho...
this is the internet
Who is selling glass test tubes?
I've been through several glass test tubes. Keep knockin the damn things over. So I've gone to using a glass flower vase, heavier, more stable, works great.
Big R
Big R
High % ABV Alcohol is a solvent for plasticizers so your distilate shouldn't touch any plastic at all. Not even the famous 'Solo Cup'. I don't think you want plasticizers inside you or any of your friends.
S&S
S&S
"If it worthwhile then it is worth a little extra time and effort... all impatiens ever got me was burned fingers and charred eyebrows"
the tube that came with mine wrinkled up instantly, and turned foggy. rendering it useless. Needless to say, i poured the test sample in with my fores. If ya use it, just dont keep the sample.
-Control Freak-
AKA MulekickerHDbrownNose
The plastic collars for glass test vessels give some insurance. I'm going to make a test parrot out of copper for testing so it'll be harder to break. I was born without coordination and still have none.
heartcut
W. H. Auden
W. H. Auden
When I Google Plastic Test Tube I get sites that want to sell me in bulk and the sizes seem to be the kind one sees in chem labs. Anyone got a link to a place I can buy one test tube big/deep enough to float the alcoholmeter?
u dont want plastic...but brewhaus.com sells both but i strongly suggest the glass
+1 no plastic one. After reading this thread I don't know why you would want one?
Any good homebrew or wine making supplier should sell the glass ones. If they don't and all they offer is plastic ones. I don't know that I would buy from them anyway.
My wife and I use a pyrex 100ml Glass Graduated Cylinder, has a good base and I have to knock them over several times to break them. Good stuff, but I'm looking forward to using metal.
heartcut
W. H. Auden
W. H. Auden
Why didnt I think of that. The missus' has like 8 of them under the sink, just checked, fits perfect in most of them not too big either....Brilliant!rtalbigr wrote:I've been through several glass test tubes. Keep knockin the damn things over. So I've gone to using a glass flower vase, heavier, more stable, works great.
Big R
6
Total Abstinence is the way to handle the Alcohol Problem...circa 1891
engraved on a water fountain in the town I was born...
+1heartcut wrote:....I use a pyrex 100ml Glass Graduated Cylinder, has a good base and I have to knock them over several times to break them....
