Third run, ready for some more knowledge
Nat-X
Post by Nat-X »
My first run was a cracked corn/malted barley run that became my cleaning run :shifty:
My second run was a sweet feed/sugar run. Good results.
The wash I'm getting ready to run is a thin wash, first recipe above plus more water and sugar.
After I decide which way I want to go, I'll start preserving my yeast and using 25% backset.
Here are my questions:
How important is it to keep the wash clear when collecting it for the still?
I've been completely draining my grain, filtering through a fine sieve, then running. I'm sure the
cloudy stuff is mostly yeast?
Should I be siphoning off the clear layer and leaving the cloudy liquid/spent grain for my backset?
If I start the next fermentation immediately, I assume the yeast will grow again?
If I can't get to the next batch for a week, can I keep the yeast alive by periodically adding
in some sugar and aerating?
I obviously dont want to boil the backset because it would kill the yeast, so when do I add the backset,
when I would have otherwise added yeast?
Just soliciting an opinion here, but what's better, cracked corn (chicken feed) or freshly ground
deer corn?
Tried to malt some deer corn. Smelled like vomit after two days. Fail! :thumbdown:
I read up on thumpers. My still is 5 gallons. Does a 1 gallon thumper with a 32 oz charge of
tails sound about right?
So far, no headaches or other ill feelings. :thumbup:
Thanks!
This topic has 3 more replies
Register Login
