Amount of liquid needed for an alcometer?
Boots
Post by Boots »
I just tried to use my alcometer to see what my abv was on my first test run, but I only collected about 400 ml, which I guess is not enough to float the thing. Is there a minimum amount of liquid needed. I did the spoon burn and it was nice and blue, only getting a little beard at the very end of the burn, which I guess is a pretty good thing.
TRANSPLANTED HILLBILLY
Post by TRANSPLANTED HILLBILLY »
400 ml is more than enuff in the right sized vessel :roll: . I use a 50ml cylinder when i measure close to cuts filled to around 40ml so the hyrometer doesn't displace my nectar all over the floor. I also have a 250 ml for measuring larger samples.
I am, however; close enuff to a city large enuff to have a chemistry hobby store. So the gathering of such items is pretty easy.
see if the wife or the like, has a clear small diameter flower vase that you could,
um, :wink: borrow :wink: :wink: . preferably clear smooth glass.
Hope this helps
If it was easy everybody would do it.
Please join the Partnership For an Idiot Free World.
Big J
Post by Big J »
You need something like this:
http://morebeer.com/product.html?product_id=18656" onclick="window.open(this.href);return false;" rel="nofollow
But preferably glass.
Cheers,
J
Hackers
Post by Hackers »
In my experience you are OK if you have a 100ml test tube and your ABV is less than about 50% otherwise your sample may not be large enough.
Cheers
Grant
Never do tomorrow what you can do today because if you like what you do today you can do it AGAIN tomorrow!
golden pond
Post by golden pond »
As long as it floats, it will read. I use glass test tubes with a base at the bottom.
Boots
Post by Boots »
Thanks. I think I can track something down that will work.
sherriff Buffoerd pusser
Post by sherriff Buffoerd pusser »
Dont use a plastic wine test tube as in picture it will eat glue from bottom and turn tube itself cloudy also has a very funky chemical smell to it. :oops: I got one of the daughters to borrow me a glass test tube from high school chem class it works well. :twisted:
whats life without a challenge
Boots
Post by Boots »
Defnitely no plastic. There's all kinds of medical supply stores near my house, cuz I live in geezerville, I'm sure I can grab a test tube from one of them, or at least search around the house and come up with something.
Watershed
Post by Watershed »
I used to get away with a 25ml ultra narrow cylinder until I dropped it.
I'm thinking of making one in copper - it would still be readable if I filled it to the brim.
Boots
Post by Boots »
Gonna have to grab something this weekend, I have the results of my first run that I want to test, and then I want to do my real stripping run this weekend. I really have no sense of smell too, like none, I couldn't even smell anything on the wine distillation, but it burned really blue. I don't think I'm going to be able to tell heads, tails, or nuthin without the alcometer.
junkyard dawg
Post by junkyard dawg »
I made a nice one out of the stainless dip tube from a keg. (after using a plastic version one time...) Just a few minutes with a hacksaw and you can cut it off 8 inches or so below the valve... just turn it over and the valve end makes a good base. It's a little large and you have to fill it all the way to read. Have to set it into a jar to collect all the run off. Work too hard to use that as counter polish... anyhow, it'll get you buy till you can find a nice glass one.
These guys has some awhile back...
http://www.sciplus.com/category.cfm?subsection=4" onclick="window.open(this.href);return false;" rel="nofollow
Boots
Post by Boots »
That's a cool site. I have more access to getting a test tube than a keg, unfortunately, but I'm sure that if I need to, a quick trip to home depot would yield something.
