masonjar
Husker, I'm glad to see that you interpreted the 'Compleat Distiller' book the same way that I did concerning cooling tubes. Unfortunately, we interpreted it partially wrong. I built my still without cooling tubes flowing through the column at all, and it basically works as a pot still. The temperature gradient that was mentioned in 'Compleat Distiller' does not ever develop because my entire 3 feet of column packing very quickly becomes hotter than the boiling point of the wash, and no condensation occurs through the packing. I, in fact, noticed NO difference between packing and no packing at all. After some careful thought, I now believe that the cooling tube at the bottom of this design is utterly useless. It just wastes energy and water, and it disturbs the temperature gradient, effectively making half of the column height wasted. The cooling tube at the top, however, is crucial to the temperature gradient because it is what brings the top of the column down to 172F by repeatedly condensing the vapors and encouraging repeat distillations. It's like getting the condenser from the Nixon/Stone still and shrinking it and lowering it down to the very top of the packing. If I could rebuild my still, I would put the top cooling tube in there, but not the bottom one.
I do agree that the top cooling coil/tube is the workhorse, even in the design shown in the first post of this thread, and any lower tube/coil are "disturbers" of the process. However, with that design, there is NO (or very little) mechanism to control this reflux (if using just the top coil, which would be the best design). That is why I am so sold on the valved reflux Nixon Stone head design, especially the v2 design where there are 2 valves, 1 for output, and 1 for reflux. With that setup, you are doing a 100% controlled re-adding cooled product right back to the top center of your column packing. Thus, you eventually (hour to several hours) end up with a very good working equalibrium, and can do a much better job of fractionating out the different components that were originally mixed within the mash.
Yes, the tube/coil through the column at the top, "will" produce a reflux effect, and build up a gradient of progressively higher proof vapor in your column. But the contol is simply not there.
H.
