Is there a way I can set up my access to these forums so I can just display anything new that's been posted since I was last on here? Sometimes I just want to see if any new threads were started or if there were any new responses to older posts have been added.
Thanks Moderators.
I just want to check for new stuff
Shine on!
- Husker
Also, you should see different colored "icons" next to the forums with new posts (or threads), and when you click on a forum, the actual new posts/threads are colored (yellow on my screen).
It does not show which posts are the new ones, but if you know the last time you were on, simply click the post, then look at the time/date stamps.
NOTE for this to work, you must be logged in. Also, I use the subsilver profile. I am not sure if this matters or not.
H.
H.
