polishing
12g/mol
I think that it depends upon the amount of contamination. I have found that if the vodka is drinkable, but still has a detectable smell, then the time of contact and amount needed is minimal. I suppose if it's worse, then it should just be distilled again.
Try a couple of hundred grams packed into a pipe with a couple (maybe 3) coffee filters tied onto the end of the tube to slow the flow rate and increase contact time.
Generally activated carbon is indeed very active, and a small amount can remove the smell from a large amount of vodka and still have room for more impurity adsorption.
The trick is contact time, and this can be minimized with the use of a column.
If you want to learn more about it, check out this online book by Gert Strand. Its pretty good, but he confuses absorption with adsorption:
http://partyman.se/free_ebook.html" onclick="window.open(this.href);return false;" rel="nofollow
Good luck,
Bryan.
p.s. It may get messy.
Good luck,
Bryan.
