Should I add more yeast
I started a mash about 5 weeks ago, the temp hasn't exactly been ideal, I checked the SG today with a beer hydrometer and it read 1.025, there is no bad smell or sum on top, it's now producing 1 bubble from the airlock about every 2 minutes. Can I run this off or should I add some more yeast to speed it up?
did the cap fall. is it blue. if it is kick the barrel over if it aint charge it up. you never want it to quit workin an some folks like to runin alittle bit sweet. so im tole. they say it will want to puke runin it sweet. these boys are talkin about only corn the old way they aint made corn no other way.
didnt start with much sugar an id get me one of them tester that goes to 1.160 if you start makein wine
More yeast may not help... hard to say if you don't know what you started at. There is some reason why it didn't ferment out fully in the first place. Just adding more yeast is not likely to help... thats the crux of a stuck ferment. If it smells good and tastes good then you might consider running it and using the backset to make a new mash. pay attention to sg, ph, nutrient levels and aeration at the start. make a starter of good yeast and try again. no sense whipping a dead horse...
Use the calculators on the parent site to figure out how much sugar and water to use and get a good hydrometer or two...
did you put 5 lbs of sugar to one gal of wine. an it only read about 1.060 to start find you another tester. that would be 250 lbs to the barrel. you wont find no yeast that will work all that sugar off. distiller yeast wont do that. yeast goes to a certain point an likker kills it. when you run it you got to run it real slow cause it gonna want to puke quick. so im tole
I used 5 kilos of sugar( about 11lbs ) for a 23 litre wash ( about 5 gallons )"goose eye"did you put 5 lbs of sugar to one gal of wine. an it only read about 1.060 to start find you another tester. that would be 250 lbs to the barrel. you wont find no yeast that will work all that sugar off. distiller yeast wont do that. yeast goes to a certain point an likker kills it. when you run it you got to run it real slow cause it gonna want to puke quick. so im tole
I will run it with my stove top pot sill so I can cut the temp back.
I used Defiance instant dried yeast to start it ( 8 grams ) yesterday I added a satchel of brewers yeast, gave it a good stir and it's working again (Brigalow brewing yeast ) normally used for beer."junkyard dawg"what else did you put in the wash? How much and what kind of yeast too? When you say brewers yeast, what do you mean? There is a dried brewers yeast that is not active yeast, its killed yeast that is a nutritional supplement.
