Parrot design question
charliewaffles
Post by charliewaffles »
I understand the the design of the parrot and want to add one to a Bokabob but one thing that is a concern. If I take the output from my condenser into the base of the parrot, won't that create a blockage/back pressure in the output line that will either cause the vapors to go out the top of the still (assuming I have a hole in the double helix condenser at the top of the Boka) or disrupt the reflux operation since the obstruction makes it hard to control the output rate?? Thanks.
This topic has 2 more replies
Register Login
