Cooling water in a close loop
Does any body have done a close loop to cool the coolant of the condenser? Anybody knows how it can be done? I've done some research and I find it pretty complicated.
Problems I met:
- Find a proper radiator, I mean, a big enough radiator to cool 2.5Kw with about 1 gal/min of water with its fan.
- Find a pump strong (high pressure) but low flow (1gal/min) to overcome the head loss of the radiator and the condenser.
Finding all that under 400$ seems also complicated.
Anybody has suggestions?
Problems I met:
It's never good enough, keep working on it!
"The only thing that sucks about using a pump, is you are just trading one energy for another. I use enough electricity to power my heating element. I wish I could utilize renewable energy more in the city."
By using a radiator, you can reuse the energy to heat your house.
You don't put a big amount of hot potable water in the drain.
I think it's enough to try to do better.
For the 50 gallon drum, I not sure running 3kW for 4 hours would do do the without overheating. It is not convinient when you live in a small appartement and you need to move you still in the closet.
- Husker
If adding some water vapor to the air is not a problem (it may be a problem if you distill in an apartment, or in your basement), one can do this:
Tub of water. Submersible pump (aquarium or fountain). A towel suspended above the water tub. Small fan.
1. Pump the water to your condensor.
2. The returned water you put onto the top of the towel (to trickle back into the tub).
3. Run the fan (a tiny fan is all you need), to blow some air across the towel.
4. Evap from the towel will keep the water cool.
Doing this, you recycle your water, but it does not heat up (much). However, you WILL add moisture to the air, and if doing this indoors, that may not be feasible.
H.
H.
I like your idea! I could be a good one if I could do that outside! By the way, this principle is called adiabatic saturation. Since indoor temperature and relative humidity are respectively about 25 and 50, the only possible drop of water temperature is about 5 degC. That's not enough, or I would need too much water flow = big pump!
yeah, muckanic is quite right, if dont have any super-oversized still, it should be quite sufficient to have a lot of water in the system, as it will take a long time for all that to heat up. You may try to put a stone or brick in the freezer over night and then just put in in your water container, I do it that way, and its more than enough (but i admit i got a smaller still) just make sure no dust or tiny crumbles comes off, as that would damage your pump
To each his own.
