A good deal now at Costco for an air mover.......
Soggy Bottom Boy
Location: Somewhere to the north of the.. ..Peoples Яepublik of Kalifoяnia
Post by Soggy Bottom Boy »
For those interested, I found a great deal at my local Costco on the MIGHTYmini Air Mover by shop-vac. I wasn't able to find it on costco.com though, and knowing Costco, it's probably not available at all of their stores either. But, it might be worth checking out if you happen to be there. The item # on my receipt is 684584, so you could probably call your local store to see if they have it before you make a special trip.
$47 with $10 off coupon = $37 out the door.
The cheapest that I have seen it anywhere else was $47 from some no name .com source. At sears.com it's $69 shipped
Shop-Vac Store wants $109, Fastenal wants $141 for it, that's crazy money for it. .....but for $37 I might just go back and get another one from Costco. Of course, you all know where it was made, ....China, where else!
It's a good way to make sure of no alcohol vapor buildup, if placed and used properly. Also, it is quieter than I expected it to be.
Shop-Vac Air Mover® MightyMini® 1032000 Features:
Quickly dries wet carpets or hard floors
Dry walls or ceilings with second & third positions that focus air sideways or upward
Top carry handle makes it easy to carry
3-speed air control lets you adjust level to your needs
Easy access plug-in lets you connect multiple units
Specifications
Shop-Vac Air Mover® MightyMini® 1032000 Specifications:
Power Cord: 10'
Airflow: 500 cfm
Electric Rating: 120V, 60Hz, 1.5A
Warranty
1 Year Warranty
