Temperature control
If it plugs in, post it here.
emeraldshine
Temperature control
Post by emeraldshine »
Hi folks i'm new to this site, im building a reflux colum still using a keg and was wondering if this would work as a heating controller i'm in Ireland so parts are difficult to find.
http://www.ebay.co.uk/itm/121085046547" onclick="window.open(this.href);return false;" rel="nofollow
bellybuster
Re: Temperature control
Post by bellybuster »
you'd be much better off going with a resistive input SSR and a simple potentiometer. Very easy to build. and easy to source parts no matter where you are
http://homedistiller.org/forum/viewtopi ... ller+build
You can go the PID route but much more difficult to put together and the PID must be run in manual mode if it even has it. Large learning curve. You also need a power source for the PID
emeraldshine
Hi thx for the reply had a look online seems your correct looks like a lot of hassle to modify
