so my 2' boka is almost completed (thank god!!)
and I'm looking for a voltage controller for my spirits runs, I a network engineer not an electrician so some help would be great
the 3 options are and prices (just for parts, labour is free)
simmerstat (the knobs you have on your oven) $50NZD
phase angle controller $120nzd
or a 2kw element that can be run as 1kw element (is essentially 2 elements joined together but can be seperated) $80
I was thinking the simmerstat would be to slow to hold voltage so I would loose reflux
I'm leaning towards the phase angle controller
If anyone has something pre built or any ideas, feel free to chime in, I would appreciate it
which would be better (element control)
- sambedded
Re: which would be better (element control)
For boka you need a precise power control. So phase-angle controller is your choice.
You can easily build you own using something like this - http://www.ebay.com/itm/10000W-220V-SCR ... 0915909547" onclick="window.open(this.href);return false;" rel="nofollow
For about $55 USD, you can build your heater with element and controller as outlined in my post here:
http://homedistiller.org/forum/viewtopi ... 2#p7086197
There are other controller threads that detail putting the components in a box and adding a fan for cooling. HTH!!
thanks guys, I was leaning that way anyway
