Perforated plate distillation column VS just packing copper
newb1
Hi all, I am confused about the Perforated plate distillation column. I'm looking at buying a still and am told by the seller that a pot still needs to be run a few times to equal the output quality of a Perforated plate distillation column. They do sell a copper scrubber (mesh) filled column that's better than nothing at all but not as good.
The perforated plate distillation column is twice the cost of the other mesh or scrubber filled column.
I asked (but they couldn't explain) if the column is filled with copper mesh or copper disks with a bunch of holes in them, how does 1 out preform the other?
Here's a pic of what I imagine inside the perforated plate distillation column.
straight_shot
Re: Perforated plate distillation column VS just packing cop
The simple answer is that with packing, you aren't refluxing anything and it's just passing through and out.
With the plates and a deflagmater, its increasing reflux until you let it pass through, thereby increasing the proof of the final product.
Just because you can act like a douche bag, doesn't mean you should!
Prairiepiss
Not really.straight_shot wrote:The simple answer is that with packing, you aren't refluxing anything and it's just passing through and out.
There are many factors involved. Normally a packed column is referencing a reflux still that uses a packing like copper Scrubbers. And it will in fact reflux. And in general is used to produce neutral or vodka. Now if its a packed pot still that is a different story.
My suggestion is. Take the time to research the differences. We can't explain all the differences to you in this thread. It will take more then that. And you should no these differences before you just buy a still. That info is readily available here on HD. Take advantage of it. Learn the theories. So you can make a well informed decision.
The other thing I would like to point out is. If the one selling those stills can't tell you this info. Or what is packed in his stills. Then you should not buy from that person.
straight_shot
My misunderstanding I guess, thought the OP referenced a pot still.Prairiepiss wrote:Not really.straight_shot wrote:The simple answer is that with packing, you aren't refluxing anything and it's just passing through and out.
Thanks for the clarification.
newb1
Not much help from a neophyte's point of view. I have searched and my post is the only one posing the question that compares the two. What are some key words I should search for here to gain more knowledge about these two options?
mash rookie
Prairiepiss
What I was trying to say I guess is. You should research the theorys of each. So that you know what each does and why. Then you can make a better decision. It's not really a subject you can just search for and find and easy answer. Although MR's link is a good one. If you don't at first understand some of the fundamental differences between packing and plates. And the theorys behind them. It may cornfuse you further. Just saying.newb1 wrote:Not much help from a neophyte's point of view. I have searched and my post is the only one posing the question that compares the two. What are some key words I should search for here to gain more knowledge about these two options?
Spriit Tisler
Is there yet any consensus what does best job on doing neutral azeotrope: scrubber wool packing, lava rock or perforated plate column? I'm getting myself a TIG welder and was going to look for making perforated plate 3-4" if it appears the best.
- der wo
You shouldn't use plates, if your only goal is a neutral. IMO buy SPP. Perhaps copper SPP.
Why not Der wo,?....A four pate column with a short packed section above the plates will make excellent neutral.der wo wrote:You shouldn't use plates, if your only goal is a neutral.
- der wo
Packing has a smaller HETP than plates. So you need less length for the same purity. And as far as I know less diameter for the same wattage.
I don't say, you cannot run or modify a plated column to a good neutral still. But Spiriit Tisler wants to build a new still for making neutral. A packed column is much cheaper, smaller and easier to build than a plated column with the same purity.
StillerBoy
S.T. and S. B. you guys should read this thread by Mash Rookie on column packing and his research on plates and column.. it is very interesting what is said about packing and different column packing.. lots of info on packing, speed, column size and and energy used.. flutes are not the best for what you intend to do in my view.. http://homedistiller.org/forum/viewtopi ... =1&t=30727
Just some thoughts
Mars
Just some thoughts
Mars
– Albert Einstein
– Albert Einstein
RedwoodHillBilly
+1der wo wrote: A packed column is much cheaper, smaller and easier to build than a plated column with the same purity.
A fairly short (1M or so) CCVM is dead simple to build and run. It is cheap and makes a very good neutral.
Spriit Tisler
Many sources cite SPP as not the best possible option, especially when considering it's price and limited availability.
RedwoodHillBilly
For neutral, I run a 3" x 36" CCVM with copper and SS scrubbies, and it will run azeo all day long.
StillerBoy
What are the sources you are coming from with the above quote.. and have you taken the time to read the posting thread above..Spriit Tisler wrote:Many sources cite SPP as not the best possible option,
Mars
– Albert Einstein
– Albert Einstein
