Calculator: Alcohol Content of Sugar Wash w Temp Correction
Distillate Of Nerd
Post by Distillate Of Nerd »
I have been getting lower alcohol outputs then expected with WPOSW and was wondering if it was because I wasn't temperature adjusting my SG measurements. I know a lot of people over estimate their distillate % because they don't temp correct it(94% at 90F is really 91%). I heavily hacked together a few scripts I found on other sites and wrote a temperature correcting ABW calculator. I don't have a site to post it to so I thought I would would just post the html here. If anyone wants to use it on their site (or the Home Distiller site) feel free. To test it just copy and paste the code into a text file and just open it in a browser.
The long and the short of it is even at 90F the correction is only .004 which isn't nothing but isn't huge, it will throw the ABW off by .5%. I don't run the ferment quite that hot. I pitch at 85F, then let it cool to 82F for 2 days and then lower it to 78F for 2 days and finish at 72F. I control it with an aquarium heater. Going from 85F to 72F is around a .25% change.
DoN
Code: Select all
<html>
<head>
<title>Alcohol Content of Sugar Wash with Temp Correction</title>
<!-- modified/written by Distillate of Nerd and posted to the homedistiller.org forum.-->
<!-- as far as I am concerned anyone can reuse, rewrite, repurpose or host without my permission.-->
<!-- This page was hacked together from a unattributed script found here: http://merrycuss.com/calc/sgcorrection.html-->
<!-- If the original author complains please comply with his wishes. No offense was intended by its modification.-->
<script type="text/javascript">
// function for dealing with Celsius
function conversionc() {
//Sets variables; data from form named "abwtempcor"
var sg1=document.abwtempcor.StartSG.value;
var temp1=document.abwtempcor.StartTemp.value;
var sg2=document.abwtempcor.FinalSG.value;
var temp2=document.abwtempcor.FinalTemp.value;
//Convert sg to a floating point number
var sg1=parseFloat(sg1);
var sg2=parseFloat(sg2);
//Convert celsisus values to fahrenheit
var temp1=(9/5)*temp1+32;
var temp2=(9/5)*temp2+32;
//Calculates SG correction for 59F from HBD http://hbd.org/brewery/library/HydromCorr0992.html
var correction1=1.313454-(0.132674*temp1)+(0.002057793*temp1*temp1)-(0.000002627634*temp1*temp1*temp1);
var correction2=1.313454-(0.132674*temp2)+(0.002057793*temp2*temp2)-(0.000002627634*temp2*temp2*temp2);
//Round off correction values and convert to SG scale
var correction1=(Math.round(correction1))/1000;
var correction2=(Math.round(correction2))/1000;
//Adds SG correction to the measured SG
adjustedgravity1=correction1+sg1;
adjustedgravity2=correction2+sg2;
//Round off adjustedgravity
var adjustedgravity1=Math.round(adjustedgravity1 * 1000)/1000;
var adjustedgravity2=Math.round(adjustedgravity2 * 1000)/1000;
//Percent Alcohol Content by Weight
var abw=(adjustedgravity1-adjustedgravity2)*129;
//Round off ABW
var abw=Math.round(abw * 1000)/1000;
//sends the calculations back to a form named "abwtempcor"
document.abwtempcor.resultsStartCor.value=correction1;
document.abwtempcor.resultsStartAG.value=adjustedgravity1;
document.abwtempcor.resultsFinalCor.value=correction2;
document.abwtempcor.resultsFinalAG.value=adjustedgravity2;
document.abwtempcor.abw.value=abw;
document.abwtempcor.scale.value="Caculated in Celsius";
//function for dealing with Fahrenheit
function conversionf() {
//Round off ABW
document.abwtempcor.scale.value="Caculated in Fahrenheit";
</script>
</head>
<body>
<h2>Alcohol Content of Sugar Wash with Temp Correction</h2>
<form name="abwtempcor">
<table Border=1 width=480>
<tr>
 <td>
<input type="text" size="5" maxlength="3" value=60 name="StartTemp"> Starting Temp
 </td>
 <td>
Temperature correction: <input type="text" size="5" id="resultsStartCor" value="0" readonly>
 </td>
</tr>
<tr>
 <td>
<input type="text" size="5" maxlength="5" value=1.050 name="StartSG"> Measured Starting SG
 </td>
 <td>
Corrected SG: <input type="text" size="5" id="resultsStartAG" value="1.050" readonly>
 </td>
</tr>
<tr>
</tr>
<tr>
 <td>
<input type="text" size="5" maxlength="3" value=60 name="FinalTemp"> Final Temp
 </td>
 <td>
Temperature correction: <input type="text" size="5" id="resultsFinalCor" value="0" readonly>
 </td>
</tr>
<tr>
 <td>
<input type="text" size="5" maxlength="5" value=1.050 name="FinalSG"> Measured Final SG
 </td>
 <td>
Corrected SG: <input type="text" size="5" id="resultsFinalAG" value="1.050" readonly>
 </td>
</tr>
<tr>
 <td>
Percent Alcohol in Wash: <input type="text" size="4" id="abw" value="0" readonly>%
 </td>
 <td>
<input type="text" size="25" id="scale" value="0" readonly>
 </td>
<tr>
</table>
Click to Calculate: <input type="button" value="Fahrenheit" onclick="conversionf()" /> <input type="button" value="Celsius" onclick="conversionc()"
</form>
</body>
</html>
Distillate Of Nerd
Re: Calculator: Alcohol Content of Sugar Wash w Temp Correct
Oops, minor brain fart on my part. It calculates ABV not ABW. I checked it with the calculator here: http://homedistiller.org/calcs/alcohol_content" onclick="window.open(this.href);return false;" rel="nofollow and it returns the same results if you set the temps as 60F.
googe
Post by googe »
I've never thought about temp correcting with SF/fg, interesting, I'm not to worried though, I just care about the end abv after stilling.
"Homer J Simpson"
Prairiepiss
Post by Prairiepiss »
For a sugar wash I calculate the potential ABV and SG using the calculators on the parent site. Before I make it. I then test the SG to double check to make sure its right. Using temp corrections if needed. I already know my Target finishing SG. One never been off that terribly much
Distillate Of Nerd
googe wrote: interesting
I agree the correct word is interesting not relevant. It was really just to see how temperature affected the calculations. With that said I could show two examples:
1.06SG@90F -> 1.02SG@70F = 5.16% uncorrected 5.55% corrected = .39% correction
1.09SG@80F -> 0.98SG@70F = 14.19% uncorrected 14.44% Corrected = .25% correction
The first is an error of 7.5% and the later is an error of 1.7%. I guess I would feel that a 2% error isn't worth noting but 7.5% is. Either way I agree it isn't incredibly important, I suppose I just like the precision. It also helps me learn how things work to be able to play with numbers.
DoN
Maritimer
Post by Maritimer »
Distillate Of Nerd wrote:It also helps me learn how things work to be able to play with numbers.
Hear, hear!
M
