I'm nearly finished with my 15.5 gallon keg boiler build and have been stressing over what kind of still head to throw on top of this when it's complete.
I started out by reading "Making Pure Corn Whiskey" and "The Compleat Distiller," twice each. Both recommend using packed column based stills, with Ian Smiley even stating he uses one for flavored spirits in his work. I had pretty much come to the conclusion that a 2" VM build was the right place for me to begin my distilling process.
I've spent a lot more time reading online, both here and at Artisan-Distiller, and it seems that the majority is uncomfortable using a still with forced reflux for flavored spirits, instead suggesting that if my focus is bourbon and scotch (which is about 90% of what I drink) that I should be starting with a pot still.
I assume most of the answers are going to be "what's nice about this hobby is that you can't make a wrong decision" or "eventually you'll want both so you can use the pot still for stripping runs if you're making neutrals," but I'm looking for a more direct and practical answer. I assume I'm going to eventually end up with both, but as someone who hasn't distilled at all, which makes more sense to build first?
To me, a pot still seems to make a lot of sense as the runs will be shorter (if anyone can give me an idea of how much shorter a 10 gallon wash will be in a pot vs. a reflux still, that'd be helpful information), so I'll be more likely to distill more often. Distilling more often would get me more experience faster and it would hopefully be a faster learning tool to rub off the layers of being a newbie. I also assume that since making cuts is more difficult with a pot still, learning the skill would help eventually when I move to neutrals, as I'd have a deeper understanding.
However, starting with a reflux seems reasonable as well. Cuts will be more predictable by temperature. It seems to me learning to distill and learning to make cuts at the same time may be like learning to drive a manual, where you're learning two skills as once, rather than learning on an automatic transmission where I can just worry about learning to drive. While the runs will take longer, as long as I can get a product I'm happy with, I'm sure I'll be pushed to keep distilling.
It's pretty easy to make good arguments for both sides. I'd be very interested to hear from you much more experienced folks on your takes on what makes the most sense to start with. Thanks for reading all of this, and thanks in advance for your replies!
Also, so it's not a 100% image free post, see below pictures of my keg with holes drilled out (burned out a LOT of hole saws) and 2" ferrules welded in, along with some feet to get the keg off the floor along with my in progress work on my Variac based element controller.
![Image](http://s21.postimg.org/vsa0tbu1z/keg.jpg)
![Image](http://s21.postimg.org/mj7uj7l5z/controller.jpg)
