My first VM still - run
kaziel
Post by kaziel »
Just want to share with you my awesome exp after completing my first ever VM still and my first run, below parts:
Boiler - 30L keg with welded (tig + CO2) 5/4" heating element port,
Heating elements - 1.4kW + 2kw SS,
Controller - up to 5.5kW phase angle, digital 0.5% step 0-100% range,
Column 50mm (2") diameter, 120 (4') high, tri clamp fittings, material 304 SS, welded with tig + argon, whole thing etched, passivized and electro-polished,
Head 45cm (18"), 1" take off, 316 SS ball valve (PTFE seals) 1" to 3/8" 316SS reducer,
Liebig 75cm (30") inner tube 3/8 (1m - 40") jacked 35mm (1.25") 75cm jacked lenght 304 SS,
Reflux condenser 304 SS flexi tube 8-10mm outer diameter, 0.3mm thick,
2 tri clamp PTFE easy gaskets,
Packing SS scrubbers + 25cm (10") of copper SPP,
After doing cleaning run and checking for leaks I've couldn't wait for my WPOSW to finish so I've run 14L of my old wash (sugar+raisins) starting ABV was 10%. My power on run was 1.8kW and my boiler was not insulated (column was insulated pretty good). Fores & heads were extremely nasty after bleeding them i was collecting 100ml every 7min (850ml/h) abv of spirit was 97% @14C! I know you can't go pass 95.6% and 97% is due to my alcometer accuracy but I'm very pleased with outcome.
I've got 3 thermo-ports in column. Had only one installed (30cm below takeoff). I'm planing to move to eARC in a short while after I've finish my valve control. Thermometer in a base of a column is for auto start/stop process (cooling water, power), 3rd thermometer is in take off. I'm also planning on filling my whole column with SS SPP (only got like 1.2L now).
Vodka consumed wisely is harmless even in large amounts.
My all stainless 2" VM still
My all stainless 2" pot still with Dimroth condenser SS Pot Still
My malt mill - two roller - DIY
My keggle - mash/filter tun
This topic has 10 more replies
Register Login
