DMX controlled element
If it plugs in, post it here.
cb_j
Post by cb_j »
So humour me, i've got knowledge and access to lighting dimmers (3 phase, 2400 watts x 12 channels) but there are also smaller ~1000 watt dmx controlled dimmers around from electronics shops...
Would a DMX controlled dimmer be suitable for a heating element?
In the practical regular case, the dimmer controls a light, from 0% - 100% power. (but usually has a small minimum output.)
(DMX = lighting control, usually.)
http://en.wikipedia.org/wiki/DMX512" onclick="window.open(this.href);return false;" rel="nofollow
Cardinalbags
Re: DMX controlled element
Post by Cardinalbags »
You should read these two sections of the new distillers reading lounge on controllers:
Phase Angle Based Controllers:
http://homedistiller.org/forum/viewtopi ... 62&t=17383
Triac Based Controllers:
http://homedistiller.org/forum/viewtopi ... 0#p6961070
I don't know the specifics about DMX controlled dimmers, but dimmers themselves controlling in line are typically not recommended.
cb_j
Post by cb_j »
Cheers, more info -
DMX Control Dimmer Kit
This kit allows you to control a lamp or group of lamps through a DMX signal. You can use the USB Controlled DMX Interface kit (Cat No. KC-5480) or any other control console compliant with the DMX-512 protocol as a controller. It will drive resistive loads like incandescent lamps and mains voltage halogen lighting.
Specifications:
• Load capacity: 1000 W @ 230V (5A) or 500W @ 115V
• Power Input: 115/230 VAC
http://www.jaycar.com.au/productView.asp?ID=KV3614" onclick="window.open(this.href);return false;" rel="nofollow
Cardinalbags
Just a fancy way of explaining a household dimmer switch. They cant push enough power without melting. I would not use them. I highly recommend either building your own controller, and if your not comfortable doing electrical work, then have a look at this thread by Jimbo on his electrical conversion - take note of the 10000W control module.
http://homedistiller.org/forum/viewtopi ... =2&t=43456
cb_j
Post by cb_j »
comfortable with electrics.
i just had an idea that may be useful... dmx control software would be capable of automating the element. software is free, build-your-own dmx hardware control kits are inexpensive and i already had everything i would need if it were appropriate.
and yes, it is a fancy household dimmer switch... :) but handles more power... :)
