Voltage\amperage question
If it plugs in, post it here.
raven_r_one
Post by raven_r_one »
Hi again -
While my 110/15a build is going well, every time I'm in a home improvement store, I can't help but contemplate a 240 option.
There are several breaker options - which one should I choose?
30/50/60? Gfi?
Cardinalbags
Re: Voltage\amperage question
Post by Cardinalbags »
30 amp DP breaker is sufficient. 5500W element is only 25 amp draw at 220v and that is about the biggest element you would ever need for the hobby scale.
raven_r_one
Cool!
A local brewer runs 2x 6000 watt elements, so set me adrift.
What about gfi?
muddog
Post by muddog »
GFI is a must have
If you building are a new service I'd go with 50A, just cause. Not much difference in cost.
If you are replacing a breaker with a GFI breaker in an existing service, for example your dryer circuit to run a boiler then you must use same size breaker.
I run 5500W on 15 Gal keg, it's more than enough. muddog
Simple pot still for simple likker
Moonshine and oysters, the breakfast of champions
"Don't turn on the lights cause I don't wanna see. Mama told me not to come" Randy Newman
raven_r_one
Yeah - I had the "just because" mentality too.
I have a 200 amp panel, figured I could go higher.
I can't decide if I'm going to put the outlet near the main box and run and extension or buy the 10/3 or 8/3 and run it out to the garage.
If it makes it into the garage, 50a would be enough to run a small welder (I'm hoping).
(The utilitarian in me)
superdaveva
Post by superdaveva »
30 amp #10 , 40 amp #8 ,50 amp #6. If its a long run ,go one bigger. Personally I just use a regular breaker, dryer outlet.
just deal with it bitches
