Heating element orientation question
If it plugs in, post it here.
Nutmegmooner
Post by Nutmegmooner »
I've been reading and thinking a LOT lately about converting my 15.5 gal. boiler to electric. Bought a controller kit and as I was assembling it I was discussing things with a trusted friend. He suggested that I need to orient the inchworm shaped heating element up and down rather than flat. My question to you fine folks is does it matter? As I have already figured out that it has to have enough room to rotate as I thread it into my couple, affecting where I drill my hole, meaning it can't be right close to the bottom. What say you wrt flat or up and down? Love to hear your thoughts!
aquavita
Re: Heating element orientation question
Post by aquavita »
Ah - I think that if you set it vertical, you run the risk of a partially exposed element.
I know that some elements say they can handle being "run-dry", but I wouldn't want to try it.
Even in water heaters they are horizontal.
The KYChemist
Post by The KYChemist »
aquavita wrote:Ah - I think that if you set it vertical, you run the risk of a partially exposed element.
+100! With that kind of a suggestion, I would listen to any future suggestions politely. Then, if unsure for reason, bring said suggestion here. Let the pros, NOT including myself, guide you in the right direction.
Nutmeg do you mean having the element mounted vertically as it strait up from the bottom.
Or having a horizontal element rotated so that the loop is vertical.
Soggy Bottom Boy
Location: Somewhere to the north of the.. ..Peoples Яepublik of Kalifoяnia
Post by Soggy Bottom Boy »
I saw a HLT with 2 vertical, wavy elements in it, just last night.
One Camco 5500 and one 4500 element mounted in the bottom of the pot, sticking straight up. .....but they were mounted in 60+ gallon pot used to heat up water for brewing, so low liquid level is not an issue. In a small pot where you are significantly reducing the volume of liquid by distilling, .....probably not such a good idea!
I'll get a pic of it next time I'm there and post it up.
S-Cackalacky
Post by S-Cackalacky »
Weird, this same exact question was asked several months ago. I think in that case as well, the friend was deemed an idiot.
