Super noob
StillTheMan
Super noob
Post by StillTheMan »
Just wanted to say whats up to allmy fellow mentors. I have been researching this stuff for a while and am just now ready to get started on it all I think. I purchased a reflux/column still and I have no idea how to use it haha. I have used a pot still but the results are not what I want. I am looking for the best possible way to get the highest yeild cheep. I gave the following recipe a test and it failed bad maybe some help from some of the pros could make a grasshopper like me a grow a bit :-)
--Sugar Shine--
Ingredients:
5 gallons water
8 pounds of white sugar
Procedure:
Heat 2 gallons of water (to no more than 120 degrees) and add sugar a few pounds at a time. Stir until dissolved and add more sugar. Keep adding sugar until all sugar has been added / dissolved. Dump this mixture into a fermenter and add 3 more gallons of water. Shoot for a final temperature of 96 degrees an adjust heat of additional water accordingly. Add 2 tablespoons of Alltech Superstart Distillers Yeast once final liquid temp is 96 degrees. Aerate by dumping back and forth between two buckets a few times. Shoot for a constant fermentation temperature of 90 degrees for the shortest fermentation time and highest alcohol yield. If your house / garage / basement / wherever / isn't this warm, wrap your fermenter in a blanket and use a heating pad if necessary. Leave it sit for a week or two to ferment and another week to settle.
Halfbaked
Re: Super noob
Post by Halfbaked »
Welcome stilltheman. Id hit the tried and true section and the new distillers reading lounge. Good readin and give you some insight on refluxin.
T-Pee
Re: Super noob
Post by T-Pee »
One word: nutrients.
Time to do some serious reading, bro. Then you'll know just where you went wrong.
Start here:
The Rules We Live By: http://homedistiller.org/forum/viewtopi ... =35&t=5090
Then:
The Parent Site: http://homedistiller.org/" onclick="window.open(this.href);return false;" rel="nofollow
Finally:
New To Distillation forums: http://homedistiller.org/forum/viewforum.php?f=26
Yes, all of it and no skimming...READ. You'll be glad you did since spoonfeeding here is kept to a bare minimum. We want you to be safe and succeed but you have to do your part.
"Quality, not quantity."
Welcome to HD! :wave:
tp
superdaveva
Re: Super noob
Post by superdaveva »
Welcome aboard, you came to the right place, read read read, don't gt in a hurry it will all fall into place. Good luck be safe and enjoy a great drink.
just deal with it bitches
Zak Griffin
Re: Super noob
Post by Zak Griffin »
I am looking for the best possible way to get the highest yeild cheep"
I assume you're making alcohol for fuel then? Not to drink, obviously...
