Would this work?
If it plugs in, post it here.
jabrone
Would this work?
Post by jabrone »
I'm installing electric heating elements in my 15 gallon keg boka I'm building this summer. I'm completely inexperienced with electrical work so I'm a bit intimidated to follow some of the great plans on here. Some of the commercial controllers are quite expensive. That said, would this work?
http://www.amazon.com/240v-Electric-Bre ... 395&sr=1-5" onclick="window.open(this.href);return false;" rel="nofollow
Re: Would this work?
From the specs it looks fine. Kinda' pricey tho. But if "turn-key" is your requirement, it should work for you.
Grey_Meadow
Post by Grey_Meadow »
Jabrone,
My personal thoughts are you should try to build your own. That is part of this hobby and it is a good education. It really isn't hard and it is a most entertaining endeavor. You still will need a power source, either an existing dryer outlet or get a new one installed. If you do decide to build your own there are a lot of folks here ready to help.
For a reference point, I priced the components to build a simple controller, including a power switch and ammeter indicator.
I came up with about $120 for all the pieces. The most expensive component is the power cord.
Grey.
Grey Meadow
jabrone
Post by jabrone »
Thanks guys. Think I'll try DIY after all.
