Don't know if this will work.
And I'm not good enough at math, to use the engineering formulas, I found while searching.
In the past I've used the hot waist water from the PC to preheat the next still charge.
Could a pre-condenser reclaim enough energy to heat a mash barrel?
Info.
Keg pot with a 4000w heat on a stripping run.
The mash will start with boiling water having been added to the grain.
Heating the mash barrel
