Making the optimal yeast starter ...
Odin
Post by Odin »
Now, I don't normally make yeast starters, but here's an interesting read on yeast reproductive rates. If I interpret things correctly, the following oulines may apply:
1. PH of around 4.6;
2. Temperature of around 35 degrees C;
3. Sugar content of 110 grams per liter.
The paper does not mention aeriation, unfortunately.
https://bib.irb.hr/datoteka/389483.Arro ... _et_al.pdf" onclick="window.open(this.href);return false;" rel="nofollow
Regards, Odin.
rtalbigr
Re: Making the optimal yeast starter ...
Post by rtalbigr »
My practices in my wine making are somewhat different from my whiskeys. I am much more concerned with sanitation for one thing.
As related to the yeast I have never tested the pH of any of my wine musts, although they are all rather tart so I imagine the pH would be around 4.5-5.0. I ferment at a much lower temperature, even for starting the yeast, more like 18-24 C, depending on the yeast strain I am using. I always rehydrate the yeast though @ temps of 35-43 C and always use rehydration nutrients like Go Ferm.
I never aerate a wine must, although I do add one drop of olive oil/gal.
Big R
DAD300
Post by DAD300 »
Good find Odin...for me this paper makes temperature the prime player and makes me consider we start with too high a specific gravity.
Red Star instruction sheet for DADY
Re-Hydration method;
Re-hydrate in a stirred vessel prior to pitching. Sprinkle the dry yeast
into 10 times its own weight of water or wort at 35C ± 3C (80F ± 6F). When the yeast is
reconstituted into a cream (15 to 30 mins), continue to stir for another 30 minutes. The yeast
cream is then ready to pitch into the fermentation vessel.
http://www.fermentis.com/wp-content/upl ... 6/DADY.pdf" onclick="window.open(this.href);return false;" rel="nofollow
Implies aeration by stirring, but says nothing about ph...
DSP-AR-20005
