Hi everyone newb here, I have a still spirits super reflux still that I have been using for year or so now, and have got the hang of making pretty smooth vodka, I also age it on oak and add commercial rum essence for my rum. My question is if I take all the packing out which are ceramic saddles will this allow me to run it like a pot still. because I would like to make a real rum wash with molasses and run that through. the column is not very tall about 4 inches.
sorry for the dumb question thanx Bundy_dan.
reflux as a pot
I think it would work. What is the output you are getting with packing? When I used to have one of those still's I think I maxed it out at 80%, it's was a long way off the results gained after building a Bokakob inline. I think the still spirits super reflux minus the packing would produce spirit at probably 70%, my home made pot still starts at about 68% so I think you should be right.
Definately run it faster, rather than the drip, drip, drip required for neutral you should be aiming for a stream perhaps the size of a toothpick. As for the temps, it is too hard to say, peeps need to know there own setup. Just collect in stubbies and find your hearts the next day.
- Location: 50 miles past kikatinalong up that dirt track
Rubber is bad mmmmmmkay, you should replace it with cork. Don't remove the water all togethor, just the one that is about 2/3 up the column.
