4 lbs sugar
2 gallons water
tspn dap
2 pkg bread yeast
starting sg 1.080
after 2 days stalls, sg 1.070
added quarter cup crushed cheerios (2 cups uncrushed)
starts cooking now
2 days later sg 1.010
today sg is 2 little lines below 0.990 (0.996 ?)
racking to 2 , 1 gal. jugs to clear (in frig ?)
how long before i run it ?
thanks for the help
Ready to run?
- Shine NOLA
Ready to run?
for everything bad, whiskey; for everything good, the same
- jedneck
Re: Ready to run?
Run it soon as it clears or any time after.
big help
Dunder
big help
Dunder
Re: Ready to run?
are you going to run only 2 gallons? is it worth it?
- Shine NOLA
Re: Ready to run?
goblin wrote:are you going to run only 2 gallons? is it worth it?[*]
Fri Jan 11, 2013 9:25 am ---i just got a new 44 quart ss boil pot that i will use .....
Fri Jun 13, 2014 9:06 am .. i did my first SAC run the other day......[*]
WELL goblin, i didn't want to wait 18 months to build a still
And I just started
SO
yea, 1.25 gallon at a time
in my 8 qt. pot still.
on a 750 watt hot plate.
outside while working on my land.
just part of my day now.
AND I'm not worried about volume.
I'M looking for quality.
got another 3 gal
and 2, 5 gal carboy's of sugar wash working
doing an AG today consisting of
8lb corn
2lb 6row
2lb rye
got a qt and a half from last week left
i don't think i'll get thirsty anytime soon...........
and will be able to share a sip or two soon.
Why, how much hooch do you drink in a week ?
just wondering
Re: Ready to run?
Hello Shine NOLA. You are right on about quality. The volume you can deal with when you are ready. With the US cooling, as in in winter, one must check your ferments temps. 75 to 85F is a good starting point. This and checking the PH is helpful. Shine NOLA you will do just fine. srs
- Shine NOLA
Re: Ready to run?
it sure was
2 gals and i got about 40 ounces (32 at 55% and 8 at 35%)
will keep this and add to the next few runs
until i have 6 qts to run a 2nd time
by then i should be doing ok on my cuts
you can tell the difference if you taste, taste, taste
