Aging in jars with cork stoppers
jloftin60
Post by jloftin60 »
I just received my cork stoppers for my glass containers and they all fit like a sock on a rooster.
I bought them from Widgetco out of Houston,Tx. online http://www.widgetco.com" onclick="window.open(this.href);return false;" rel="nofollow
#44 size fits a large mouth mason jar
#34 size fits a small mouth mason jar
#13 size fits the 4L wine bottles
T-Pee
Re: Aging in jars with cork stoppers
Post by T-Pee »
jloftin60 wrote:I just received my cork stoppers for my glass containers and they all fit like a sock on a rooster.
Damned if I know what "they all fit like a sock on a rooster" means but a #14 fits gallon apple juice jugs nicely.
tp
cob
Post by cob »
S-Cackalacky
Post by S-Cackalacky »
The PTFE discs are probably a better solution -especially for long term storage. I have the disc for my regular mason jars for long term storage. I'll be buying a few of the 3.5" size discs for my 1 gallon aging jars. Might also get a few to fit the 1 gallon glass juice jugs I use for feints and low wines. If you have any concerns about what's used to seal the caps of whiskey bottles, I think they make the discs in those sizes too.
jloftin60
Post by jloftin60 »
I have a large mouth mason jar with a cork in it. Now I can not get the cork out.
S-Cackalacky
jloftin60 wrote:I have a large mouth mason jar with a cork in it. Now I can not get the cork out.
Yea, you gotta be kinda careful about how much pressure you put on those things when you seal the jar. Mine only go in about a quarter of an inch and that gives me a good bit to grab onto to pull them out. Even at that, sometimes it's a little difficult - gave myself a likker bath once.
Snuffy-ga
Post by Snuffy-ga »
If you put the cork in too far you can warm the jar in a water bath until a bit of pressure builds up. That should make it easier to get out. Also dont store them in an area where it gets very cool overnight, it will suck them in deeper into the jar.
slow trickle
Post by slow trickle »
You can get them out with a cork screw, but it will ruin the cork.
S-Cackalacky
Might try this if ever you get them out and want to use them again - put a long piece of kitchen twine across the diameter of the jar opening and then insert the cork stopper, leaving the ends of the twine sticking out either side. Should give you something to grab onto to pull the corks out.
