The low down on Amyloglucosidase (Y amylase)
thecroweater
Post by thecroweater »
I almost always use Coppertun dry beer enzyme ei Y amylase ie amyloglucosidase to up my yield and dry my mash. I was always led to believe that it belongs in the ferment not in the saccharification mash but this article I lifted from WhiteLab would suggest otherwise. I have been reasonably satisfied with my results but if I can do better I sure would like to know about it. Anyone got an opinion on the best way to use Y amylase/amyloglucosidase
ULTRA-FERM - WLN4100
Amyloglucosidase for ethanol or dry beer production
Product Description -------------------------------------------------------------------
ULTRA-FERM is a liquid amyloglucosidase (highly concentrated) from
selected classical strain of Aspergillus niger.
Ethanol Production -------------------------------------------------------------------
After starch liquefaction by alpha-amylase, dextrins are hydrolysed in
glucose by amyloglucosidase, before alcoholic fermentation. Ethanol
production is faster and yield is higher. The recommended saccharification
temperature is 60°C.
A suitable substrate for saccharification is a liquefied starch with a dextrose
equivalent (DE) between 10 and 20. A higher DE than 20 might reduce
the saccharification efficiency. The concentration of the substrate will also
influence the saccharification efficiency. A concentration of 20-25% is a
general practice. ULTRA-FERM dosage, for given reaction time, depends
on the amount of glucose requested. It is usually recommended to add
400 ml per ton of starch for a fast hydrolysis. Possible pH range of use is
from 3.5 to 5.5 with optimal between 4.0 and 5.3.
Optimal temperature is 60°C. Amyloglucosidase activity is completely
destroyed when the saccharified liquor is held at 85°C for 10 minutes. As
an example: a yield of 94% glucose can be obtained after 40 hours with
36000 AGI per kg dry matter; after 72 hours with 17000 AGI/kg and
after 85 hours with 13000 AGI/kg, at pH 4.5 with temperature 60°C.
Beer Production ------------------------------------------------------
Brewers often want to produce light beers or dietetic beers. In these
cases the brewer wants a controlled or complete hydrolysis of starch and
dextrins to fermentable glucose. Traditional brewing methods permit
only 75 to 80% hydrolysis of starch present in the grain raw material.
ULTRA-FERM amyloglucosidase permits total hydrolysis of dextrins to
fermentable glucose, from all types of starch.
In the brewhouse, the recommended application dosage of ULTRA-FERM
is 0.8 to 3.2L per ton of starch. It can be added at the beginning
of the mash-in. In the fermenter, the recommended application
dosage is 1.5 to 2.5 milliliters per barrel of beer, applied as the fermenter is
being filled.
ULTRA-FERM optimal pH is between 3.5 and 5.5. Temperature should
not exceed 60°C. Amyloglucosidase activity is completely destroyed when
the wort is held at 85°C for 10 minutes
This topic has 15 more replies
Register Login
