Making rum or whisky
What type of condenser do you use for making rum or whiskey? Thanks!
- S-Cackalacky
Re: Making rum or whisky
You asked something similar a while back related to making brandy. The terminology is still wrong. I suspect you mean, "what kind of still do I run to make whiskey or rum?". If that's the case, you could use a pot still, or you could use something like a CM with partial reflux. If you run much over 80%, you'll be stripping flavors and getting into neutral territory.
- thatguy1313
+1 type of condenser doesn't make a lick of difference. Type of still does. You might need to knuckle down and do so reading. Start with the link in my signature.
Thanks for the link. But reading, looking at stills and asking a person that owns a brewery, changing the different condensers and technique will help with what spirit you are making. I could be wrong but a still is the whole apparatus...the condenser is what makes the vapor back Into the liquid. From what I was told, some people just change the condenser on the STILL, for what ever they want to make. This what I was told and that is why I come to the forum and ask these type of questions. I get conflicting info, from people AND from reading. Thanks again.
Correct , and that is all that it does, changing it wont make a scrap of difference to the final product.Hardcider wrote:the condenser is what makes the vapor back Into the liquid.
