Hi all,
just getting into distilling after a year or so brewing some fine beers.
I'm from The Mornington Peninsula in Victoria , Australia and hope someone out there can help me.
I'm after the formula for water to alcohol ratio for when I'm diluting my spirit
eg.. on the weekend a friend and i ended up with 4lt of 92% spirit...how do you do the calculation to get it to 40% with out using a alcohol meter? we do have one but would like the formula
also the conversion rate for temperature when using a alcohol meter
eg.. if the spirit is 23c instead of 20c..what do you + or - to adjust the alcohol?
i did do a search of this site and couldn't find what i was after
i find the searches on forums almost impossible to use....................
stupid new guy!!
regards Jeddog
calculations for newbie
- Husker
Re: calculations for newbie
Hmm,jeddog wrote:i find the searches on forums almost impossible to use....................
From parent site, look under the "distill" section. There is a dilution tab.
http://homedistiller.org/distill/dilute/measure" onclick="window.open(this.href);return false;" rel="nofollow
http://homedistiller.org/distill/dilute/calc" onclick="window.open(this.href);return false;" rel="nofollow
