Is there any technical problem ya'll can offer if I were to use 1/2" dia. copper tubing (10 ft long) for my worm? It seems bigger than most folks use for a worm but I had it on hand and it fits nicely in a 5 gallon bucket. I'll have a copper 3/4" dia. column (2 foot high) feeding it. Thanks in advance for your advice.
1/2 inch might be harder to coil but other than that should be fine. if 10ft is enough. you said you were going to put it in a 5gal bucket. how big is your boiler. i hope less than 5gal.
The boiler is 4 gallons. The tube came coiled and only needed a little help to fit inside without touching the sides. I too hail from the Magnolia State.
I have had really good luck using 1/2" copper refrigeration tubing for worms. That is the minimum I'll use. It has a large enough cross section to prevent too much back pressure. A lot of guys use the 1/2" hard copper tubing for Liebig condensers. It has a 5/8" od though but not that much difference.
