300 gallon fermenter!
thatguy1313
Post by thatguy1313 »
So today I was offered a 300 gallon hdpe barrel that has been used for rain water collection ... for FREE! Of course I can't turn it down but when the hell am I gonna have the money to do a 300 gallon ferment? Much less the time to run all that! Any other ideas what I can use it for?
woodshed
Re: 300 gallon fermenter!
Post by woodshed »
Recirc tank for cooling.
bearriver
Post by bearriver »
I'd use it as a septic tank for my Dobermans, and be happy to have it.
I would also consider using it in an aquaponics setup. A friend of mine has a dozen or so IBC totes over 200 gallons each. The short story is he uses them for tanks to raise fish, who's effluent is used to feed indoor plants.
thatguy1313
Thought about cutting it in half and making a couple canoes outta it.
cranky
Post by cranky »
thatguy1313 wrote:Thought about cutting it in half and making a couple canoes outta it.
That would be a shame. You can use it to collect rain water :moresarcasm: . or raise tilapia in it (very popular with preppers) or go ahead and do a 250 gallon ferment instead of 300. You might have to build a bigger still though but doing the math, if you build a 25 gallon still and strip 20 gallons at a time that's only 12.5 runs, so figure 12 stripping runs. Not really so bad when you think about it. Now figure 3 strips to a spirit run and you only get 4, 20 gallon spirit runs and a years supply of hooch from a single ferment. Sounds pretty reasonable to me. :D
Truckinbutch
Post by Truckinbutch »
:wave: I like the way you think .
goose eye
Post by goose eye »
Ole boys would keep it for water. Water is a good thang to have.
So I'm tole
goose eye wrote:Ole boys would keep it for water. Water is a good thang to have.
So I'm tole
+1 times 10!
Rng4
Post by Rng4 »
I use something similar for cooling water. It sits outside my stilling shed and I run the lines thru the shed wall. Keeps all the heat outside and gives me more room in the shed. I have a buddy that works on one of the largest ranches in my state and I can get all the 300 gallon totes I can carry.
Danespirit
Post by Danespirit »
So I'm tole
Yep..! Rainwater is coolingwater for free.. + you can put a tap in there and have water for your garden. :idea:
thatguy1313
Just picked it up. Guy owned a kennel and was collecting all the condensation from the air conditioners. Said he filled the barrel in two days :shock: its already got a tap at the bottom and a hose out the top that would work perfectly for an air lock.
cranky
Post by cranky »
thatguy1313 wrote:Just picked it up. Guy owned a kennel and was collecting all the condensation from the air conditioners. Said he filled the barrel in two days :shock: its already got a tap at the bottom and a hose out the top that would work perfectly for an air lock.
So do I see that 25 gallon boiler in your future?
ga flatwoods
Post by ga flatwoods »
You would be best served with a cheap ($35) pool pump going in the top six inch hole and pumping off the clear if you intend to utilize the whole potential of the barrel
Ga Flatwoods
I am still kicking.
Ga Flatwoods
thecroweater
Post by thecroweater »
What ^ he says +1
hellbilly007
Post by hellbilly007 »
And I thought I was really doing something with a 80 gallon fermenter. Good score.
RandyMarshCT
Post by RandyMarshCT »
woodshed wrote:Recirc tank for cooling.
This is exactly what I would use it for. Perfect size.
Life member, representative, and proud supporter of the Hobby Distiller's Association.
http://www.hobbydistillersassociation.org
