This next part should help some more newcomers.
So, my first wash was made with distilled water, sugar, and highly active fast rising bakers yeast. I inverted the sugar with 2 lemons, but only for about 10 minutes, and started the yeast in a diluted solution. It all started off fine and then stuck. I later learned not to use distilled water. I also didn't add any nutrients. So I took 1/4 cup of organic tomato paste, 3 drops of Geritol Tonic, a pinch of epsom salt and boiled it with 7 grams of yeast for the protein. When it cooled to 90 deg F I added it to my stuck wash and dry pitched another 21 grams of yeast. The total wash is only about 2 gallons. I know it is a lot of yeast but from what I read you can't have too much yeast...if that is wrong please advise. I areated it very well too. Now it seems to be working fine!!
I also made another wash with some inverted sugar, only 1 lemon for 30 minutes, and the same ingredients as above; but I used a mixture of rapid rise yeast and highly active dry yeast. I dry pitched the yeast in 2 gallons of 90 deg F FILTERED water intead of distilled. It seems to be working great too.
I know of a cheaper way to keep the air out of your fermentor and still let the carbon dioxide out. It is the same method used for people with a gunshot hole in their chest. You take some clean plastic wrap and cover a hole in the lid. Tape it on three sides. When the pressure builds up it will let out the gas on the untaped side but it won't allow any air to get sucked back in because it draws the plastic up against it. I doubled the plastic to make it thicker. Seems to work just fine.
Quick question. I like the smell of the fermenting mash but my wife doesn't. Big surprise huh?
