first time ever
inspeedway
first time ever
Post by inspeedway »
this is so neat!! thank you all for this site!!
i've been wanting to do this since early 70's when miller was building their brewery in eden n.c. - met a pipefitter there from the hills-nw-nc- buy shine from him for 60$ a case (6 gallons in case) and thats when i learned that shine is a sipping substance!! my buddy and i drove 38 miles to and from work every day and that day we got a gallon to see how it was--started drinking from the jug on the way home (like we would beer)- woke up the next morning at 4 am laying on the front porch-didnt know how okie (he was from oklahoma)got home from my house!! chit i didnt even know how i got home chit!!!!learned alot from that experiance!!!!
i put a water/vinegar mix in the boiler (2 gal water(hot) about a pint of v) and fired it up-and with-in 15-18 minutes(2-am wife asleep up stairs) i had steam a-rolling and a smoke alarm going off!!!chit here comes the ole lady (done woke her ass up). probably would have got me ass chewed out but she said i had a grin from ear to ear on me face and was pushing the hell out of the buttons on that thermostat remote thingy trying to get it to shut up!!!she had put a smoke alarm on top of the furnace duct work and it was right over me take off area!! her fault huh?
she got the alarm to shut up and i turned the water to the condenser turned on and instantly the vapor stopped and water started flowing!! read where u wasnt supose to use cooling water when u was doing a clean out first time!!
temp was at 209 and never got over that -thermostat must be 3 degrees off boiling point- of 212- turned water off and veryly cranked it open and turned the heat way down and the temp fluxuated to 208 an209 and water was cold coming out and condenser was cold and coming out like goose eye's ole hand well pump!!!!will drop the arm down a inch or two at a time till i can get it to coming out evenly then when i get to run ujsm! maybe it'll twist and double like goose eye said he's tole!!!
put'n ujsm together tonight and time it ferments i will have time to learn some more about heat'n and cool'n running water through the still!!
-got a 15.5 keg for boiler, lp gas turkey cooker for power,
-10" ss mix'n bowl with 6 fasteners (over kill probably)
-2-1/2 inch brass shower drain(dont do this-too much work) use the 2" kitchen drain like they say here!!!
-3" to 1-1/2 reducer_all they had unless u buy a gross of 3 x2" for 37$ each! put an alembic style egg going back into 2" anyway-ha ha
-1-1/2 " back to 2" fitting-to get back to the 2" for reflux column
-then a 2" to 3/4 for 90 ell, to condenser
-90- 3/4" brass drain ell(might find copper) its got a drain take off screw for draining chit out of water lines and u can drill a hole in it for ure probe!
-then i used 5 foot of3/4 for product path
-then 4' foot of 1" for condenser with (2)-- 1x1x1/2 tees at the ends for cooling lines to fasten to. solder it all together!!!!
uj put this in file 13 if you want or start a book thread!! geezzzee i am a noobie trying to help noobies and when i look at it -chit i am confused reading this stuff!
i'll try to put pics on here to see what i did as a noob!
inspeedway
another pic
Dnderhead
Post by Dnderhead »
big help
inspeedway
head
i dont know how to post these a links but here is the head
[img][img]http://i213.photobucket.com/albums/cc42 ... C-010F.jpg[/img][/img]
inspeedway
10 inch bowl
for noobs like me wondering how to fasten the bowl to boiler! i had to use 6 - 5/16 ss bolts cause ace only had 5 - 1/4 inch bolts and no ss wing nuts!
for 1/4 inch-- drilled a 9/32 hole a put a 5/16 tap through it (over kill - but it did keep the bolts from falling back into the boiler until u get ure nut on it)
[img][img]http://i213.photobucket.com/albums/cc42 ... C-002F.jpg[/img][/img]
inspeedway
parts
here is the bolt,nut,wing nut and fender washer u have to bend to clip over the bowl
[img][img]http://i213.photobucket.com/albums/cc42 ... C-003F.jpg[/img][/img]
inspeedway
fastened
here is the bowl fastened on to boiler without the head attached
[img][img]http://i213.photobucket.com/albums/cc42 ... C-006F.jpg[/img][/img]
Dnderhead
Post by Dnderhead »
Wing nuts would not have to be ss but would be nice Most use flour
past four gasket " flour and water"but it looks like you got good start
new_moonshiner
Post by new_moonshiner »
Looks great looks like youre well on youre way ..maybe a tad of copper mesh rolled up in the end of that condenser not enough to block anything mind you .. it looks large enough to handle some ..that or maybe a roll or two in the column just before the outlet ..
HookLine
Post by HookLine »
Good job. Yet another use for a camera tripod!
Be safe.
Be discreet.
And have fun.
inspeedway
thanks dnhead
thanks dnhead for the welcome - probably an older coot than u though!! lol been retired and doing what i always wanted to do (NOTHING) lol i did read a long time before i registered and ask me first dumb ?, statement, and i said i can see from reading that a pot still is for sipping and flavor and a reflux is for quanity and the drunks - caught helll over that so i read some more ! there was a thread on here where u'all was gonna start a pic sticky for the noobs -well for anybody that likes to see what ya got!! or how its made!!!as far as a noob coming in here and saying (i want to drink some moon shine! how do i make it_) if i was a mod or admin!! i would be hard pressed not to boot'em right then, any way i am putting some more pics on here and hopefully in a couple of weeks you'll see a pic of ujsm comin out of that piece of copper!! thanks to all on here!!!
Dnderhead
Post by Dnderhead »
nothing like seeing someone making ago of ,it good job
Ive Ben retried four some time
dun this four Meany
years but now play withe it ,try different things even so i learn things
but i thank this computer has me beat
inspeedway
ferment
i've messed me first batch of ujsm up!!
only thing i think i did wrong was put 4-5 tsp of crosby&baker fermax yeast nutrient in the disolved sugar and maybe using k1-1116 yeast because i have a bunch of it from my wines. after 30+ hrs i took the lid off -had few good size bubbles but far between times-so i strained some of the chit off the top-stirred it up good (airieate) and pitched another pack of the 1116- tasted sweet with sour after taste-
sg was 1.070 when i started with 2-1/2 gallons of store bought water and 2-1/2 gals of my tap water-de-chlorined - 7 pds of sugar,
afix'in to go get more sugar and some active bakers yeast and start another 5 gals. will put this aside and see what it does unless some one tells me i've ruined it with the nutients or the 1116 yeast!!
this corn is from tsc i thank you people!! oh! the temp was 80 yesterday so i put it on front porch to cool it down a little!!
[img][img]http://i213.photobucket.com/albums/cc42 ... -corn2.jpg[/img][/img]
inspeedway
scrolling
chit i hate having to scroll to read - sorry about that! least i learned
how to down size the pics !
